First thing you want to do is check the wattage for what you want to run. A 30" flat screen is probably in the 100-150 watt range, laptop is likely about the same. Not sure about the fridge. They're all probably listed in ac amps and volts. Multiply one by the other to get watts. 120 volt at .5 amps is 60 watt draw, and so on. With your batteries, you'll need to know what kind of amp hours you have. That will tell you what kind of run time you'll get with the draw you figured from the watt calculations. As for the 2 100w panels, figure about 5 hours of good charging ability per day with good sun--so about a kilowatt. With monocrystal panels you'll get some charge with indirect sun or even overcast, the 5 hour is just a safe minimum to go on. It's a simple formula to convert amp hours into x watts for y time that I can't for the life of me remember, but a quick search online will reveal it.
Your laptop should be fine on modified sine wave if it has the little box in the power cord, that is there to clean up the power. The tv may be okay or it may not. Pure sine wave inverters are more expensive, but also more efficient by about 20%. It all depends on the math.
Another thing with the fridge, they don't always run. It depends on how they cycle. It may show a 600w draw, but only really run for 20 minutes per hour. That would make your peak 600 watts, but only 200 watts of draw on your bank per hour. It will effect how you calculate your run time on your bank.
