Question about oil leak on old Farmall
7.2K views 12 replies 7 participants last post by  mr.monte86
I have a Farmall B that my dad gave me and I was mowing with it tonight and noticed after I had parked it that oil was dripping on the ground. It's dripping right under where the gear shift is. I tried taking a picture but...that's not working out. Any idea what it could be?
Thanks,
Joe
More than likely the transmission seal is leaking. the only other leak would be a rear main seal under the flywheel, most of the time it would leak out the inspection plate on the torque tube.
assuming it has hydraulics , another common leak area is the bottom seal on the hyd unit. Another thing to watch out for is the engine oil level, if the hyd pump is leaking it goes into the engine oil. if you have to add hyd oil,and see no evidence of a leak on the outside, the pump seal is probably bad.
there should be a plug on the left hand side of the transmission down low to check the level. the plug on the top is where you add fluid. regular 80-90 wt gear oil is all it is.
do not over fill is, if the axle seals are bad it will leak down the axle tube and soak the brake pads with gear oil.
if you plan on keepin the tractor invest in a manual.
that is not the timing mark hole.
Yesterdays tractors should have a manual for sale. You have a seal leaking, it need replaced. transmission seal is easier then the rear main. But considering the age of the tractor it probably needs both plus the axle seals.
you will need a way to roll the rearend away from the rest of the tractor and a way to support the rest of the tractor. Since you are asking what is leaking I assume you are not mechanically inclined.
My 1st tractor was a Farmall B. I believe your rear main engine seal is leaking. The transmission oil in mine, 80w or 90w, never turned dark. These engines were designed to use non-detergent oils and if modern oils were used that could have started the leak. Leather seals and detergent oils don't always mix well. The timing mark was on the front pulley, as I remember. It's gonna require splitting the tractor to repair. That's a "BIG" job for a non-mechanical type. If it was me, I'd see if I could maybe trade into some a little more modern. Those old draw-bar tractors are neat. But, something with hydraulics, and a three-point hook-up give a lot more options, not to mention safety.
