Fire-Proofing your BIL against raiders
2.7K views 16 replies 15 participants last post by  logartist
So I hear lots and lots of talk of how raiders could throw molotov cocktails at your BIL or home and burn you out.
So this thread is dedicated to discussing things you can do to reduce the odds of them doing that successfully.
I happen to live in a Cinder Block, stucco sided home so the only thing outside that could burn is the roof. even the soffits are covered in a 1/4 layer of fire proof stucco. There's really nothing to burn except the roof.
Any plans I make to reduce the chances of being burned out will focus on the roof.
If you live in a home that has flammable externals, your challenge is a bit more complicated. But, if shtf was looking more likely, there are flame retardant paints you could have on hand for starters. Expensive, but cost is relative.
Thanks for participating in the thread.
Your friendly neighbor Fighterman.
Thank you sir.
Well, the good news is the asbestos is fire proof right? :thumb:
I think those were very popular 25+ years ago or more? I've seen them a lot on some of the rural homes I've worked on.
People with brick homes are in pretty good shape also. Those with flammable siding or large wooden porches may need to consider fire retardant coatings?
Reactions: cleatis
Sounds like you are in pretty good shape. Your main concern should be preventing internal fires (i.e. a firebomb getting in through a window) in addition to the roof. Shutters and screens should help with that, but I would recommend a fire extinguisher or two be kept available for anyting that does get inside.
Take a look at the area you live, the stability of it, and the people that live around you. The only fortification I plan on doing in my area is locking the door, keeping a close eye out, and having a loaded weapon with reach at all times. There just isn't that kind of threat in my area. A handful of junkies about 10 miles away, but they'll bother their neighbors and get shot ASAP.
I think "raiders" is a bit of a fantasy. I don't think the world will ever get that bad. And if it does, I think praying would be a better idea than fortifying.
A lot of fire risk can be mitigated by making smart decisions when you buy the home. For example, my last house was adobe with a tile roof. Nothing external to burn. It had decorative window bars as most houses do in this region. It wasn't hard to wire loops of springy fence wire to the bars that bounced bottles off without breaking them. So there wasn't really a whole lot to do to fireproof it other than put up the fence wire if the SHTF.
In a lot of areas, one can find older homes made of rock, brick, etc. The roofing system seems to be the only weak spot. And there are a number of metal roofing options.
Well, I`d have to say the best first line of defence against someone trying to burn you out would marksmanship.
One thing I`ve found handy is an interior faucet thats threaded to accept a garden hose, like where your washing machine hooks up. That`ll give you a fire fighting capability without having to expose yourself to turn it on.
Also, if you think Molotov`s are a threat, look into getting some dry chemical fire extinguishers. Putting water on a petroleum fire will only make it spread.
Agreed...
Sprinklers mounted on the roof with a central feed standpipe .... booster pump attached to the standpipe at ground level ..... wet down your entire roof and concentrate the water to the area of the roof that takes a hit .....
You would need to make this work under a grid down situation.
In fact it's fairly inexpensive. All it takes is a couple 55 gallon barrels and enough 1" PVC to go up to the roof and then across.
One barrel holds the water. The other barrel gets pumped up with air. I'm looking at making a PVC hand powered ram pump. Or you could hook up some bike pump.
Run PVC up house and then drill holes in run on top.
It might take more than one 55 gallon barrel of water. And maybe a pressure gauge for the air barrel.
Post collapse, you might use this set up for water in the kitchen.
Sierra Dave
For the cost of all that , why not just put up a sheet metal roof and be done with it ?
This match box I live in only needs a warm wind and it's toast .
The only thing that won't burn is the rotten wood . No joke.
Fortunately the barn and the shop trailor are sheet metal so with them even brush fire would have little effect on them falling cinders would do nothing .
No one much listens , but again I advise one takes a good look at fire fighting and the job it is, both in homes and in the forest , for those determined to bug out there .
Tinker toy tools are not going to work .
It takes real man tools to fight fires .
You might considder too having a water tank at as high a level as you can acquire, or have a water tank you can charge with air so you can put out fires if the city pressure is gone .
My water tanks have a check valve on them so the water cannot back feed int to city lines . Water is used through them to my washing machine out side ,so it never gets stale .
I have a gas engine driven air compressor next to the water tanks so that if the city pressure is gone i can charge the tanks with say 75 PSI and take the hose connected to it and put out fires or what ever i need the water for , even hooking it up right back into the house plumbing .
The 500 gallon cistern Is just high enough to fill the house water tanks should they get drained .
Another project is building a trailor to tow behind the garden lawn mower/tractor for dealing with fires on the property ,if any.
I have an engine driven water pump that needs some love that just might work , and along with maybe 2-55 gallon drums , that would make a substantial fire truck/trailor .
If your not prepared to fight fires , be prepared to live with the conciquences.
hidden shelter/home
I bought a concrete 1500 gallon septic tank, had em knock out the inside baffle, and then it was coated several times with water sealer. Inside measures 10 ft long, 6ft high, and 5ft wide. I also had them add a rebar ladder welded to brackets in the concrete walls. It's buried under four ft of dirt and the entrance is under a shed thru a trapdoor. If the shed burned, it wouldn't affect the shelter as a fireproof lid covers the entrance. Down below are electric lanterns, batteries, my cot, food for a year, water is from a spring nearby, my guns and ammo to hunt with and reading materials. They can have the house I live in, burn it if it suits em, but what i need is safe and away from the home. The tank has a 2" pvc pipe that comes out and up for fresh air and is hidden and a window screen covers it.
Everyone spouting that they will just kill em before they throw the moltov cocktail makes me laugh. Do you all have a 360 degree unobstructed field of view around your home with enough armed help to watch every angle day and night, and never miss a thing? All it takes is one person getting close enough to lob a bottle. You can't see through your walls.
If you have a combustable exterior on your home, fire is an issue you should absolutely plan for, whether intentionally set or not.
