DIY Bunker Door
27K views 53 replies 38 participants last post by  Post18guy
Those following the original bunker thread, sorry for the delay. Had to save up some pennies and the project turned out to be more labor intensive than I had thought. :>
Here is the Control Panel thread:
http://www.survivalistboards.com/showthread.php?t=213218
Total cost was around $625 for materials, most of that being steel. Cement, mig wire and paint came out to around $150.
The sliding bookcase hiding the entrance was a project last year and already in place, the new door was to replace a standard steel exterior door. It would of slowed the zombies down, but not really stop the motivated ones.
The walls are 10" thick concrete and plan 1 was make the door same thickness, however after some math I decided weight was going to be a serious issue. So plan 2 was 5" thick door, steel on both sides, filled with concrete.
Inside framework and tying it into the wall.
Door rebar added.
Outer framework and door skin.
Reinforcing rebar.
Filled door frame a section at a time to ensure no pockets or gaps.
Door was last to be filled, that way any settling due to weight I could make adjustments to locks. FYI, it didn't shift at all.
Sorted out the main deadbolts during occupancy, there is a smaller keyed deadbolt center of right frame, this requires a 6" key and is used primarily for securing valuables while not home.
A couple coats of paint later and things are looking less Russian.
Inside views.
Outside view after opening book case.
Book case closed, no one the wiser.
P.S. before flaming over OPSEC etc. keep in mind, this was a DIY project and I wanted to share with like minded folks. Those who have priced actual bunker doors know your looking at 7K. And just because you now know where my door is, does not mean you have any chance in hell of coming in!
Good and bad feedback welcome, I loves input!
I see you have a drop in ceiling above the bookcase. Hide a couple semi auto shotguns on each side, off to the left and right, angled down and controlled by a wire and you can negate any attempt at someone focusing on you book collection.
Thanks for the information, good to know.
Nice door!
Did you consider using lightweight concrete with zeolite when you were looking at maintaining the original thickness? Just curious.
How confident are you with those hinges and bars? Are you thinking about upgrading those later?
Thanks!
P.S. still fail for no LCARS format. :)
awesome work!
Just one thing I'm wondering.. That's an awful lot of door, but not a whole lot of lock. Is there anything that will reinforce those two "strips?" a bar or cross beam or similar? I'm thinking that the door being so solid will be the perfect transmittor of force to the two locking strips if someone were to use a heavy battering ram etc.
Edited to add:
Could you show your solution for the hidden hinges on the bookcase.. Would be very interested in how you worked that out too.
Thanks!
#7 · (Edited)
Nice Death Star. I'm sure the ventilation shaft will be secure from the Rebel Alliance behind that door.
Looks great man!
Edit: The ventilation shaft was in IV: A New Hope, this is VI: Return of the Jedi Death Star. Looks like the Empire skipped the Endor orbital shield and went to a large space bunker. They should just remember to open the bunker door when they go blow something up because if they didn't, well... that would just plain be embarrassing.
The locking bars are 3/8 steel, the span between the holding plates and frame is about 2". It would have to be a serious ram, aka 6 man operated log. I will bet starving folks will run out of energy and seek easier targets. Also the purpose of the book case, hide what appears to hold goodies.
And well, at that point keep in mind I will be inside; sitting in my chair waiting to shoot the dedicated fools who do manage a breech.
As for burning down the house, I would be rather miffed as I really like my house. However the bunker is under the side yard and only shares one wall with the basement. Contingency for us inside during storm / raiders and house catches fire is I have a roll of heavy aluminum duct work tape (not duct tape) to seal the inside.
The hinges are rated at 200# each and the door is around 1100#; keep in mind my bunker is not blast proof. Chance of a near by nuke where I live is remote, mainly to wait out raiders and protection from storms / tornado s.
controlledpress-
Here is the detail for hinges on book case:
Large offset concealed cabinet hinges pop out far enough that the side trim clears the wall. Notch was required to make everything line up with the wall correctly with the added trim thickness.
Currently using a simple ball latch to keep it closed, sometime this week I plan to sort out some sort of cable latch to secure from inside before closing bunker door.
Main technical problem was bottom trim hit the baseboard when opening. Try as I might I just could not get enough clearance to fully open the door, AND still have it not look like a door. End solution was make the damn baseboard move out of the way. Used a screen door spring to hold in place when closed, book case pushes it out of the way when opening. Spring pulls baseboard back into place when closing.
In the future, (distant?) I plan to completely redo the book case system. That room is my basement office and I want more built in book cases. So I plan to make 3, side by side. The left one will be on sliding tracks and the middle / right ones will be hinged.
Time for some ANSI art ^^
closed: |__ __ __|
open: | --v|
hmm, may have to photoshop up a better diagram...
i was looking for something for a simple root cellar. then read about what it would take to be safe from a nuclear blast. i had looked at the $5000 plus price doors but they looked like they just bought a $1200 dollar safe and removed the doors. then charged $5000 for just the door.
i think your door is way better. and the cost under $1000 makes it doable.
Great craftsmanship! I was curious to the hinges too...look like regular interior door hinges. Do you have a plan to cover them...maybe tact weld the pins? What if someone used your tools to start cutting it...what would you done to prevent it? It happens, happened at work. Someone drug a plasma cutter, Sawzaw, almost a forklift into our office of our warehouse and cut the floor safe open. A lot of people don't think so, but your tools can be used against you. I'ms sure with the prep on that door you have already played out every scenario.
I used homemade forms, a 2x8 across the bottom; wedged up from floor with blocking. Then used 14" tall plywood on each side; held with a ratchet strap around the whole door.
Filled it 14" at a time, once set up enough to not run or ooze I moved the plywood up a section and filled it again. Repeated until done.
I went this route to ensure I could poke around in the wet cement with a chunk of rebar to make sure there are no gaps or air pockets. I was going to just form the whole thing and fill it from the top; however it dawned on me that it would be almost impossible to get an even fill at the bottom and around the rebar.
I'd definitely suggest adding some backets you could put steel bars through to barricade the door, would seem stupid not to! Also keep some silicone sealant in there in case you need it.
Another good idea is to use hinges for holding the door up, and for allowing it to swing open, but having fixed hinge bars in the door that go into the frame to provide most of the security. Heres an example of a hinge bolt, albeit you'll want a big steel bar instead!
http://www.lakesdoors.co.uk/global/images/hingebolts.jpg
