Color my Brass
776 views 11 replies 10 participants last post by  ManyFeathers
#1 · (Edited)
I have a couple of NATO 5.56 firearms. I Also have a couple of 223 Rem firearms.
What I'm lacking is 223 Brass. Got plenty of 5.56 brass. So...
I want to load to 223 specs into 5.56 brass. I'm hoping to "Paint" the 223 loads in the 5.56 brass so as not to confuse the two different loads. And not get any fouling/residue in the chamber. Both of the 223 barrels are Target Match grade. One is a single shot TC Contender and the other in a semi-auto (takes AR mags).
Will a "Sharpie Pen" of a distinctive color be good, or is there perhaps a blueing compound that would be more permanent?
I am assuming the 5.56 brass can be downloaded and fireformed to fit the 223 chamber?
Ive been loading both using 223 dies and load data (same for 308/7.62) for a couple of three or four decades now, and never had any issues doing so.
Ive never seen 5.56 dies in the wild, and none of my manuals have data for it. I do have a copy of Lake City's load data from 1969, but never had the powders listed to load with, and even if I did, Id still be using the .223 dies, so theres that too.
If you want to keep things separate, you could see if you could find some nickel 223 brass. That wont come off for the life of the brass. Ive done that in the past with 30-06 when shooting matches so I could ID and recover my brass afterward.
Other than that, I also make the base of the round with a purple marker (most used black) and that made any cases that weren't nickel easy to ID.
I write on cases with a sharpie, when I’m trying new loads. Once the wind blew away the paper I had, identifying everything in an MTM box. Still had the ammo, just didn’t know which was which. So now I write on them. Wind hasn’t blown that away yet. It doesn’t come off in my tumbler (plain walnut shell), but I only tumble cases until they’re clean enough to load again.
I’ve switched almost everything to 223 over the past few years since I have guns that arent spec’d for 556 and I have guns that are so no need to worry what I’m loading into what. I’ve never seen 556 do what 223 won’t do anyway, at least for what I use it for. I know the biggest difference is supposed to be beyond 500 yards but that’s not for me anyway.
Dimensionally speaking, there is no difference in the brass, especially after you run it through a resizing die and trim it.
There could be a difference in thickness but that won't affect anything. Mixing the 2 will affect your accuracy just like shooting 2 different kinds of 223 brass.
Keep all your brass the same (lots or headstamps) for better consistency.
