chainsaw fuel oil ratios
2.5K views 17 replies 16 participants last post by  pobept75
I own an older Husqvarna model 235 chainsaw that is supposed to use a 40:1 fuel oil mixture IIRC. But, the Husqvarna web site now states they use a 50:1 fuel oil mixture - unless the owners manual says differently. I can not find my owners manual and I can not get it from their web site.
I recently purchased a Stihl model MS 261C chainsaw that is supposed to use a 50:1 fuel oil mixture. And therein lies the problem.
This requires me to keep two cans of fuel for chainsaw use. At the rate I use a chainsaw, I will either be throwing a lot of fuel oil mixture away, or I will be using a lot of old fuel.
I read that instead of throwing the fuel oil mixture away, I should just put it into my truck with a full tank of gas. Is that wise?
Also, what are the real world consequences of running both chainsaws on the same fuel oil mixture? And which one would be the best one if permissible? Or, should I split the difference and run them both on a 45:1 ratio?
I do not want to harm either chainsaw by using an improper fuel oil ratio.
Thanks for any help you can provide.
Too much oil in the mix will foul plugs, easy to fix. Too little oil in the mix and you risk cylinder/piston damage, expensive to fix.
A lot of the difference in mix ratios is from better 2 stroke oil. Good oil requires less of it.
I get rid of my older 2 stroke gas in my old truck, never had any issues from a few gallons added to plus 15 gallons.
You could add the correct amount of oil to a small fuel bottle to change the mix from 50 to 40 to 1 (that's what I would do).
I try and only use non-ethanol gas in the chain saw's.
https://www.chainsawsdirect.com/manuals/husqvarna_235e_240e.pdf
If the engine calls for 40-1 use 40-1. Attempting to use 50-1 mix will soon seize the engine due to lack of lubrication.
You can mix a half gallon or a quart or even a cup. There is no law saying you have to mix by the gallon. Use the appropriate amount of oil for the amount of gasoline. If you are worried about longevity add a fuel stabilizer into the gasoline and mix well PRIOR to measuring out for your oil mixture.
It will not hurt anything. You are talking about less than a couple ounces of oil in about 15 or 20 gallons (2000+ ounces) of gasoline.
Do not use anything less than 40-1 in the older engine, and have a few extra spark plugs for the newer engine to replace them if/when they foul.
:thumb: :thumb:
Another tip is that if you aren't sure of the ratio needed for your saw or anything else like that that has a small tank is to fill it with 50:1 and then add a capfull of oil to the tank. The worst that will happen is that you foul a plug like stated above, but I have never seen it happen even in new saws that are supposed to have the 50:1
I also have a husqv 235. I also have a stihl chainsaw and a husqv brush cutter.
I have acquired several 1 litre premixed fuel cans. I mix my fuel in the used up ones. I had one for 1:40 and another for 1:50.
I always use ethanol free gas.
As the years have gone by, recently I stopped making 1:40 for the one machine that uses it. I buy it premixed. Expensive, but I do not even use one 1 litre can per year. Runs like a charm, so it's worth paying a few more dollars, for the little use I give it.
1:50 I still make it. But my latest Stihl came with a large can of 1:50 fuel and run really smooth.
Am I the only one who fimd husqvarnas way easier to start than stihl? I do prefer the Stihl engineering, though. More solid.
Sent from my SM-A520W using Tapatalk
I just purchased a non-professional pole saw from Stihl. If you use their pre-mixed gas or their two-cycle oil the warranty goes from 2 years to 4 year and they say it will run my other saws from echo and husqvarna. Seems to be a non-brainer choice.
I suspect the high compression saws have more critical requirements relative to the fuel.
the mix rate IMHO for the most part is a recommendation. it is like directions on things that have 10 different ways to make it work, but they have to pick something and put it on the package or in the directions as The Way to do something. general rule of thumb, if it is hot out, or you are going to really work that machine, run more mix in the oil for a lot of high throttle use. for a little casual work, trimming up a few branches once in a while, a little less mix in the gas may be the way to go. if the difference between 40 and 50:1 causes a two stroke to foul plugs, it has other problems bigger than the fuel it is running.
This post has been deleted
I know this is an old thread that hasn’t been responded to in a few years but I’m not sure there is a “ common gas/oil ratio” anymore. I could be wrong though.
As has been posted upthread Opti-2 is a pretty good universal option that works for me. I’ve got 2strokes that specify anywhere from 25/1 up to 50/1 and they all run well with Opti-2 and I don’t have to have several different ratios mixed for use. I’d guess I’ve been using it for over 10 years with no issues.
