Wearing two different camo patterns or a solid bottom and camo top is better than all solids or all camo.
Prove me wrong!
Prove me wrong!
Over in this part of the state and even in the lower deserts, a somewhat faded woodland BDU blouse and DCU pants are quite effective with the vegetation. For some odd reason, the UCP ACU pants are effective for blending in up on Mingus.The problem with mismatched camo is that is doesn't look tactical. Appearance matters you know. If you look like a dweeb you'll get treated like one. But someone in ACU's with a red, tan or green beret, now that's sharp!
Other than that, you need camo to match your vegetation. I think the new ACU's with the Multi-cam were the best. If I was a camo wearing person I'd order that for the apocalypse, at least in my area. I think the newer OCP(?) has some thermal protection?
Just look to nature for camo. How many times have you spooked a deer that was just a few yards from you wearing their winter gray fur? Or had a rabbit that was sitting tight just a few feet from you when you stopped walking? When you stopped the rabbit thinks its been spotted and takes off. If you hadn't stopped you would have never seen it. Twice I have stepped over copper heads I never saw. Once I stepped on a rattle snake and stood on his head. I didn't know he was there until he start flipping around my feet. It was at that time I learned that men can fly without wings. At least for a short distance.If you want the best camo anywhere, figure out how to copy my cat. You cannot see her in the dark in a clear room. She gets under a bush in our yard and just sits. You can't see her even in daylight. Incredible camo.
Oh My!Bears.... Panthers...Apes
Canon,Ok were bein serious? Challenge accepted!
hard lines are created when one pattern doesnt match up with the other say nothing of one camo not matching the features of the terrain youre trying to blend into therein causing more contrast and being significantly more noticeable. These effect are of course is multiplied by movement.
Additionally the eye is led by lines- for example if you have a pattern that is more horizontally orientated on top and a pattern that is more vertically orientated on bottom it will multiply the effect of the afformentioned hard lines between the garments.
Different patterns and materials absorb and reflect different amounts of light- which can cause you to stick out far more than you would if your apparel was homogenous depending in on lighting conditions. This is literal and guarenteed contrast.
You as a camoflauged feature are trying to be overlooked due appearing mundane vs the surrounding flora/terrain- the more individually unique each part of your body looks the more you draw the eye as you are an anomaly within the environment. This causes you to stick out more thereby defeating the purpose of the camoflauge.
Finally the most important part of camoflauge is positioning yourself against a backdrop that works well with said camoflauge- if you put your camo on you should have an immediate idea/plan in your head as to what features you actually want to hide near. If you are wearing something grassy- stick to grassy hides. If you are wearing something barky stick next to trees etc. Mixing and matching your camo is not conducive to the goal and mindset of actually trying to match the camo to the environment itself. If you wear different sets of camo on half then the other half-, the one half will always blend better than t the type of materialhe other half vs finding a spot where your entire body blends properly.
Wheres my cookie?
Aye, don't forget a Good 'scraggly longhair'd Wig / bathrobe.. Nothing says "Homeless; Ignore" like a legit 'Jeff Lebowsky' costume.... In the city I have a few crappy looking torn shirts and stained pants I can use to make me look homeless and hopefully be ignored.
Yep, but don't forget the AL-clipboard and 'neck-lammy' with just about Any old ID in it!Yup, a hard hat, and safety vest, nobody will dare question you!
Dave,Majority of time, away from concealment, mismatched cammo gonna stick out.
I got curious years ago.
Tried digital woodland top, traditional woodland pant and vise versa with woods behind me. Had my sharp eyed wife get back 50 yards and compare.
Mis matched stuck out.
Best from her eyes was traditional woodland top and bottoms.
Ive read of this before- do you have. Experience with this stuff? Ive read mixed reviews on all thise "hex" apparel. Always been curious!If you are doing it for hunting check your UV signature, most game see into the UV spectrum.
Your natural UV emissions are eyes, nails and teeth, then you should do a spectrum sweep of your garments many things will fluoresce that you dont think would. You might as well be flashing a strobe light in the dark. A cheap UV light and you can get a (ghost camera) digital camera with the spectrum filters removed from the lens. This can be used as a passive observation piece. I have several illuminators each for IR and UV in wide and narrow wavelengths, as well as professional IR and UV cameras. Its what I do/did.
For IR you want to break up your emissivity profile of exposed skin and clothing. It is not just a 98.8 degree thing. People talk about tarps and mylar poncho, while better than letting it swing in the wind those still produce an outline like stated above for the visual spectrum.
IR... glass is opaque, plastics are transparent, you can see your eyes details through sunglasses.
Emissivity it the constant that is used to determine received IR information. Use metallic based creams and paints and different materials (much like a ghillie suit) to break the IR signature up. Dont think just dropping it low is the fix that is hollywood.
Being in 100 deg temps does not make you invisible as the air does not emit a thermal signature it can scatter it some. It acts the same in the entire spectrum from UV to visible to IR and beyond each end think Xray and raidio. You know when you heat a piece of metal red hot that is you seeing into the thermal spectrum it just takes a lot of energy to see it with the naked eye. Like a visible object a thermal object has to have a physical mass in order to absorb, reflect, or radiate in that spectrum in order to be observed.
The terminator mud works not so much as a cooling agent but as an emissivity scale scattering.
This is an emissivity table and notice "SKIN" is almost a perfect 1 (constant) There are more detailed tables out there. So use this to make your IR blind and camo. You want layers with air gaps for blinds buildings you dont want to be the black square in the amber field of view. Think gold films on screens shield and glasses for NASA/military it is there for a reason. You dont need to take it to the extreme of polished metals just a few percent offset next to each other will break a thermal pattern. Metallic grease paints for skin... even desiccant can be ground up and used as a cream.
2 mins after touching a wall
Yes your dog sleeps on the couch but hears you coming
That was the cat not me on the couch
There is too much info to place in just this spot I have done similar postings in SB on this if you want to look or PM if you have questions so as not to derail too much.
