Yes it will fit fine. But I would also suggest ironwood. Or a K-var stock set if you are looking for plastic.
You will need a lower hand guard retainer and a new gas tube with retainer.
Gas tubes go for around $30 or so and you can order a lower handguard reatiner from brownells for like $25. There are other bolt on reatiners from dinzag, carolina shooters supply, etc. But those are expensive for what you get.
Either way you will need to fit the retainer to your barrel via drimmel tool or hand file. All you have to do is line up the retainer with the lower on. Make a mark where the retainer screw/pin will go. Then make your cut.
Go slow and take your time. Making sure to check fitment and alignment. You only get one shot at it so be carefull.
I'm about to do the same when I can settle on a stock set. I still can't deside between a wood stock set or going metal and plastic.
Hope it turns out alright for you.
OH! and we are going to have to see some pictures when you are done
