I am brand new to this forum as this is my first post, but I have done some research on this very subject lately and what I discovered is that it requires much less than what you suggest to disinfect 55 gallons of drinking water.
Here is what I have found:
Using granular calcium hypochlorite to disinfect water is a two step process.
The first step is to use some of the granulated calcium hypochlorite (or pool shock) to make a "chlorine solution" which will then be used to add to the water to disinfect it. In order to make the solution, you should use one (1) heaping teaspoon of the 78% calcium hypochlorite to two (2) gallons of water, (or use half that much to one gallon of water). Mix this in until the calcium hypochlorite is dissolved.
The next step is to then add some of the solution you just made into the water to be treated. The mixture should be one part of the newly made chlorine solution to 100 parts of water. So, if my math is correct, you should use about 1/2 (.5) gallon of the chlorine solution to 50 gallons of water to be treated.
Your suggested use of 25 teaspoons full would treat something like 5,000 gallons or so.
I'm a newbie, therefore there is a good chance I could be wrong, but others will no doubt chime in to add their expertise to your question.
