1 - 7 of 7 Posts
Merely a free thinker
I just bought a Mosin-Nagant M1891/30 Sniper with an original PU scope, and I would love to shoot it but I want to make sure that the age of the scope would not make it fragile or bad to shoot. It would be a shame to ruin a piece of history for a few rounds of fun.
Is shooting original (and old) WWII scopes like the Russian PU scope on higher caliber rifles like the 7.62x54R bad for the scope? I cant seem to find any info on this.
Thanks in advance for the help.
Should be fine. Make sure the screws are sorta-tight and maybe mark the screw locations (white line through the slot and out so you can see if it's still lined up later). Check every five shots for a while and be sure to check if the group opens up.
If you shoot a lot of rounds rapidly, you can expect the group to open up due to the barrel getting hot.
I could very well be wrong but I imagine an old scope will lose clarity more rapidly from heat rising off the barrel compared to a modern scope with better quality glass, too. Or am I way off track here?
Just remember two things:
1) The PU was designed to be used in the field in conjunction with a 7.62x54R caliber rifle like the M-N.
2) They are as tough as the rifles they were designed for.
You should be fine using that scope as it was intended to be. :thumb: :thumb: :thumb:
The larger issue is likely reflections from the lack of modern optical coatings and fogging because it's not filled with nitrogen.
I don't have issues with mine but I generally shoot it in mild conditions.
Red Neck American
Just keep it DRY.
the old scopes tend to fail/fog in wet weather. the seals inside are the issue, ad over 40- or 50 years, they get hard, shrink, crack, and that lets moisture in. once it gets wet and fogs, its toast.
Are you sure that it's an original? The Russians have been making replicas for decades.
Old scopes when brand new fogged up! They also broke internal wires.
1 - 7 of 7 Posts
