1 - 17 of 17 Posts
Does anyone know of any place that would sell a steam engine that would be big enough to turn an alternator to charge a battery?
Think of it, a steam engine setup to power a alternator to charge a set of batteries. All of the wastes they doesn't go to the compost pile goes to fuel the fire. Turn that waste to energy.
How about using parabolic mirrors to heat the steam chamber?
Any web sites looking at this?
Nuclear power does this mabe they will let you use there steamer? j/k ... I dont know of anything mabe you could rig somthing up like a small verson of a nuclear set up? just using a diff fuel heh!
Discussion Starter · #3 ·
Great, I was wondering when I would see my next useless post.
Steam engines are very large for their output. Those huge tractors from the ealy 1900s that were the size of a locomotive only put out about 40hp. My 6 hp Briggs struggles with a 100 amp alt under full load.
Salad Shooter
You might also be able to get a "twofer" out of this.
If you can find a steam engine to work you might be able to capture the steam after it's done it's work and distill it back into pure drinking water.
Low cost energy and clean water out of the deal.
Good luck. Let us know if you come up with anything interesting.
Hi Josiah, surely steam engines will take a huge amount of power to fuel them? Any energy you put in (including money) will be less than what you get out.
Why not just go Eco?, once you've bought solar panels and windmills they will churn out energy for free.
You can buy the kits on the internet, set them up yourself (that will take quite a bit of the start up cost out).
Insulate your home, if not by windows and doors but by hedgerows and trees acting as wind breaks (although I believe you live in a hurricane ally?). If you can make these fruit flowering then all the better.
Having said all that, I know I'm talking to the converted. :eek::
Johnny.
from an earlier post of mine:
Demand for solar power is rapidly heating up (see "New Solar Technologies Fueled by Hot Markets").http://www.technologyreview.com/read...104&ch=biztech
But constructing and deploying large photovoltaic panels to generate electricity remains expensive. Now two groups at MIT are working on alternative approaches to solar-based electricity that could significantly cut costs -- and put the ability to harvest electricity from the sun into the hands of villagers in poor countries and backyard tinkerers alike.
During a stint in the Peace Corps in Lesotho in southern Africa, Matthew Orosz, an MIT graduate student advised by Harold Hemond, professor of civil and environmental engineering, learned that reflective parabolic troughs can bake bread. Now he plans to use these same contraptions to bring power to parts of Africa baked in sun but starved for electricity. His solar generators, cobbled together from auto parts and plumbing supplies, can easily be built in a backyard.
The basic design of Orosz's solar generator system is simple: a parabolic trough (taking up 15 square meters in this case) focuses light on a pipe containing motor oil. The oil circulates through a heat exchanger, turning a refrigerant into steam, which drives a turbine that, in turn, drives a generator.
The refrigerant is then cooled in two stages. The first stage recovers heat to make hot water or, in one design, to power an absorption process chiller, like the propane-powered refrigerators in RVs. The solar-generated heat would replace or augment the propane flame used in these devices. The second stage cools the refrigerant further, which improves the efficiency of the system, Orosz says. This stage will probably use cool groundwater pumped to the surface using power from the generator. The water can then be stored in a reservoir for drinking water.
The design uses readily available parts and tools. For example, both the feed pump and steam turbine are actually power-steering pumps used in cars and trucks. To generate electricity, the team uses an alternator, which is not as efficient as an ordinary generator, but comes already designed to charge a battery, which reduces some of the complexity of the system. And, like power-steering pumps, alternators, including less-expensive reconditioned ones, are easy to come by.
As a result, the complete system for generating one kilowatt of electricity and 10 kilowatts of heat, including a battery for storing the power generated, can be built for a couple thousand dollars, Orosz says, which is less than half the cost of one kilowatt of photovoltaic panels.
"You can't afford something that's designed for solar. You have to buy something that's mass-produced for something else -- that way the cost is reasonable," says Duane Johnson, owner of Red Rock Energy, in White Bear Lake, MN, who developed and sells thousands of the inexpensive LED-based sun-tracking devices Orosz uses to orient the solar concentrators. Most of the devices are used to position photovoltaic panels, he says, but some people are using them with old satellite dishes to concentrate heat and make steam. Sales of his devices have been growing 25 percent a year, a rate similar to that of the solar photovoltaics industry.
Repurposed auto parts aren't the only way to go. Amy Sun, a graduate student in MIT's Media Lab, has designed an inexpensive system that uses heat from a solar concentrator to drive a type of turbine originally patented by Nicola Tesla. Rather than making complex, difficult-to-manufacture bladed turbines, Sun turned to the Tesla turbine, which consists of simpler flat disks stacked like records on a central shaft. The disks are carefully spaced to allow steam to flow between them. As the steam flows, friction between the steam and the surface of the disks causes them to rotate. "Once I have rotational shaft work, I can couple it to almost anything -- an air pump, compressor, fan, mixer, grinder, sewing machine, refrigeration compressor, and, to power those very few things that are truly electric in nature, an electric generator." She calculates that this system, which she says is simple enough for an eight-year old to make, can produce cheap power.
Of course the overall economics of these solar generator systems depend on how long they will last and how much maintenance they will require. The lifetime for Orosz's system could be quite good, since it uses parts designed for rugged service in vehicles. It also works at relatively low temperatures that, in addition to making it safer and easier to work with, won't strain the performance limits of the plumbing used.
Having already built a working prototype, Orosz's next step, which he hopes to accomplish starting this September in Lesotho, is to optimize manufacturing and set up a financing system, drawing on a recent $100,000 World Bank grant, to make the system affordable to villagers who would likely use the generator in a community center and as a battery-charging station.
Although their system was originally designed for Lesotho, Orosz and his colleagues believe it might appeal to amateurs elsewhere. "Backyard tinkerers could build it themselves. No doubt about it," says Amy Mueller, an MIT graduate student who's taken on a leading role in Orosz's project. "Matt's dad has one of these that we built to heat his Jacuzzi."
RockOut w/ your GlockOut
I have an idea for a semi small steam pulley, kinda like a pinwheel. The steam would be piped into the center of a wheel on bearings and jetted out the edge of the wheel at an angle.
I'm basically brain storming for something to run this: http://www.northerntool.com/webapp/w...50883_150883or or some kind of Belt Driven Generator Head .
Recommended Engine: Gasoline 2 or 3 HP; Electric: 1.5 or 2.5 HP
Engine Speed: Gasoline: 4000 to 5000 RPM; Electric: 4000 to 5000 RPM
Belt driven
While writing this I had the basic idea of using a pneumatic tool like this: http://www.northerntool.com/webapp/w...5133_200365133
Drive (in.) 1/2
CFM at Load 8
Speed - No Load (RPM) 5,500
Max. Torque (ft.-lbs.) 400
W/ close to 400 ft lbs of torque, I could enlarge the pulley of the drive side significantly. I already have a keg w/ a great seal set up for distilling, so I could basically set up a pony keg I have, the same way w/ necked down piping. It will need some sort of pressure valve.
I'll be ordering the water pump soon and getting to work on it, so I'll let you know what I come up w/.
A steam engine would need constant attention, it's expensive, and a potential bomb. Solar, wind, or hydraulic would be more realistic.
How about this one? I think this concept looks promising and plan to get one to power my 23 ft. boat to test it out. The most powerful ones develop some 500 HP wich doesn't sound too bad. Also it looks pretty simple to assemble and maintain with mostly off the shelf parts.
http://www.greensteamengine.com/
Looks pretty cool, would be worth a try, but, you still got the boiler problems.
You would need
clean water, de ionized
cleaning chemicals
fuel(wood coal, oil gas.)
Steam turbine( spare parts we be non existant after shtf) and you will need lots of spare parts
to much hassle for the final product
I know, but according to my brother who is a plumber a regular waterboiler might do the trick for such an enginedesign.
I don't really know. I'm no engineer. But it will be fun to try it out though. If it runs my boat on a 8 hour fishing trip it has done its job for me..
1 - 17 of 17 Posts
