Does anyone have a solar powered chicken coop led light, or a 12 volt solar powered light in their chicken coop?
After I build the rest of the chicken coop and enclose the run, I am thinking about putting a solar power / battery powered hotwire around the edge of the run.
Since the coop is going to have 12 volt battery power with a solar charger, I thought about adding a light system, and a low powered night light.
A welding shop I used to work at used a 12 volt light system. We had some portable boxes that stepped the 110/120 wall voltage down to 12 volt dc. We then used 12 volt dc powered lights inside the pipes we were working in.
My first thought is to have a 12 volt light in the middle of the coop. That way I do not have to worry about running 110 out to the coop.
My second thought is to have a 12 volt led light. This would be like the lights used in RVs, or on boats with a cabin.
Lets see if we can break this down:
Solar panel will charge battery
Battery will power light and hotwire
Use either 12 volt or led lights in coop
Solar power for chicken coop
The one thing that I worry about is the solar cell not being able to keep up the hotwire and the light. In respect to power draw, I am thinking about going overboard on the hotwire system. Instead of buying a hotwire system for lets say 1 mile of wire, maybe go with a hotwire system for a 3 or 6 mile run.
Even though I only need about 30 - 40 feet of hotwire, the larger hotwire system comes with a larger solar cell.
I see it as a trade off, buy a larger solar cell / hotwire combination, then use the extra power for the chicken coop light system.
Tractor supply has some hotwire systems for various lengths of wire and various sizes of livestock. From what I understand this is supposed to be all-in-one units with solar cell and voltage regulator.
The area under the laying boxes is where I am thinking about putting the battery. From there I might run the wires in 3/4 inch PVC pipe.
I would also like something where I could plug a nightlight into so the coop will have a soft light at night. It would be nice not to leave the chickens in pitch black darkness for whenever a predator comes around.
The light inside in the coop does not need to be very bright, just bright enough to stick my head in, look around, make sure everything is ok, maybe even bright enough to collect eggs.
12 volt RV lights should be easy to find. Its the 12 volt LED lights that I am a little concerned about.
And what about the power consumption between LED and a regular 12 volt light. For conserving power LED is probably the best route to go.
The problem I am running into is the hotwire tractor supply carries is Zareba, and it looks like their systems are 6 volt, and not 12 volt.
I might to end up putting together a separate hotwire and lighting system.
