I have a ptr91 that shoots .308 ammo.Is there anyone out there shooting one to and what ammo are you shooting out of yours.Iam looking for some cheep stuff to shoot out of it.
Exact opposite with a PTR. They have commercial barrels chambered in .308 Winchester not 7.62 NATO.Try the german 7.62x51. I would avoid the commercial 308 stuff as its probably too hot. The german surplus is readily available in the range of .40 to .60 a round. I like ammoman and sgammo.
I was at the range when they tested the first ptr-91 The Hartford gun club.There are real hard core on quality.They would run out to snag spent rounds and look at them.I have a ptr91 that shoots .308 ammo.Is there anyone out there shooting one to and what ammo are you shooting out of yours.Iam looking for some cheep stuff to shoot out of it.
Unlike the 5.56/223, there is no difference in the chambers for 7.62X51, and the .308 Win. The only difference in the two rounds is in the brass. Military rounds have a thicker web (the bottom third of the case), than do the commercial rounds. This results in less case capacity in the milspecs, so load data for .308 should be revised downward slightly if military cases are being used. Rounds that are intended for use in machine guns are usually considerably hotter than those used in rifles, so be careful when buying surplus.Exact opposite with a PTR. They have commercial barrels chambered in .308 Winchester not 7.62 NATO.
I have shot some NATO surp out of mine, British Radway Green, functions fine had 2 fail to ejects out of 75 rds.
For the cheap I use Silver Bear .308, it is steel cased but it is zinc coated so it won't gum up the flutes.
Stay away from SA ammo as it is tar sealed and if you have an AW serial # you will want to avoid that like the plague. I had some Aussie that gummed up the works on my old one, didn't shoot any through my new one.
From the ptr web site, they have a list of ammo not to used.
At this time we have identified the following types of ammunition that are known to cause problems in our rifles:
* South African
* Winchester white boxes marked 7.62,
* Venezuela Cavim
* Austrian (Hirtenberger)
* Some lots of German
* British (under powered) will not cycle action
* Indian (Over powered)
Before giving dangerous and wrong advise, think twice.Try the german 7.62x51. I would avoid the commercial 308 stuff as its probably too hot. The german surplus is readily available in the range of .40 to .60 a round. I like ammoman and sgammo.
How is that dangerous or wrong?Before giving dangerous and wrong advise, think twice.
I'd have to say so. Actually, given the handguards and match bbl, I like the PTR more so. Given it's built off licensed HK tooling, not sure if we can faithfully call it a clone, in the same way we do a hesse or special weapons piece of garbo.Is this clone in the same quality as H&k G3 or Swedish version AK4 ?
If so i would call this a bargain ! The G3 is a wonderful weaponI'd have to say so. Actually, given the handguards and match bbl, I like the PTR more so. Given it's built off licensed HK tooling, not sure if we can faithfully call it a clone, in the same way we do a hesse or special weapons piece of garbo.
Maybe, but then again it isn't to exact HK specs. The flutes in later ones are not like originally designed...I'd have to say so. Actually, given the handguards and match bbl, I like the PTR more so. Given it's built off licensed HK tooling, not sure if we can faithfully call it a clone, in the same way we do a hesse or special weapons piece of garbo.
