I don't have a central HVAC and about 12 years ago added a 14000 BTU PTAC heat pump under a window in the kitchen eating area (small bistro table). The window height was just right to accommodate the unit.
A couple of days ago it stopped and i started an online search for an inverter driven replacement. In trouble shooting I found that maybe it just needed to be reset. Further investigation revealed that the reset was on the power cord which plugs in so close to the floor it isn't visible. A reset didn't help so I kept going with the search.
This morning I woke up with the thought that the reset was GFCI rather than OCI. I tried reset with fan only and it worked but immediately tripped if I selected either heat or cooling mode. I checked the schematic to see if the controls or fan used any 120V circuits and none did so I lifted the ground and it works. No metal is exposed with the cover in place but I checked the chassis with a neon tester and no voltage was indicated.
So I have bought time to do further searching for an inverter driven unit for more economical operation and sound reduction. I found only one PTAC that uses inverter technology, the Friedrich FreshAire. I am also looking for a floor mounted ductless split system that might fit but so far they all seem to be too tall to fit under the window which is 21¼" from finished floor. Width could be up to 72".
I am not asking for anyone to do a search, just if anyone has seen a floor mounted ductless split system or a PTAC that might be worth a look. Ideally someone should produce a ductless split system designed to directly replace 42" x 16" PTACs.
