Just be aware, if youre using anything with tritium, it only has a practical usable life of about 10-12 years. By that time, the vials are usually pretty dim and will need to be replaced. Ive always ended up replacing the night sights on my handguns at around 8 or 9 years, as they are noticeably dimmer at that point than fresh sights.
I considered getting the Trijicon dual FO/tritium low powered scopes when they first came out, but at their price point, and the longevity issue of the tritium, I didnt see the point.
Early on, the first red dots I had were the old Armson OEG type sights that used FO and tritium. They worked, but werent the best, and unless you had bright light for the FO, or eyes adjusted to the dark for the tritium, the dot was often hard to see. Forget about moving between different lighting.
I understand not wanting to use batteries, but these days, that being a problem is pretty much a non-issue. With good sights anyway. Im still using M2 series Aimpoints that are 20+ years old, and have never once had a dead battery with them. And the couple of sights on guns I use regularly, are on 24/7/365. I change the batteries once a year at the fall time change. The newer versions can run up to 5-9 years on one battery.
