One thing about inverters is that they do not produce a true sine wave. They produce what's called a pulse width modulated signal (basically turning full 110V DC voltage on at varying intervals to approximate a sine wave. Plotting the area under the curve gives a sine wave).
This doesn't mean a lot to many people, but this pulsed DC has the potential to produce what's called a standing wave which is voltage that is reflected back to the source and then rides the signal out again. This can happen many times, each time increasing this very short duration, but potentially large amplitude voltage to the equipment you're trying to power.
Whenever we use variable frequency drives (large inverters to control motor speeds), we purposely buy inverter rated motors as normal motors will suffer from insulation breakdown over time if exposed to this type of pulsed power.
In your home you may never see any ill effects from running stuff from an inverter, but then again you might start to see premature failure of some equipment.
Just a thought and since we don't have any better solution for home use, I guess we're pretty much stuck with what we have.
Here's a write up on pulse width modulation if anyone cares to read up on how the DC from the battery is converted to AC
http://en.wikipedia.org/wiki/Pulse_width_modulation
