1 - 20 of 38 Posts
How long can ammo on a shelf or in storage sit for... Is it wise to buy 1,000 rounds if you know you won't shoot all of it in 2 years or so?
any input is greatly appreciated!
Dave
Good Bye
stored in a dry location with an airtight seal, 50 years is no problem. one problem with old rounds is them being trasported, and shaken. This causes the powder to grind up inside, and changes the burn charachteristics of it.
just my .02, but all my ammo is in sealed ammo cans with dessicant, and good rubber seals.
Reactions: medinaEOD
Cool and dry.
Don't set it directly on the floor, especially if in garage, etc....Put it on dunnage..the surplus GI ammo cans work great for storage.
25 Or 6 to 4
I have some stamped 1923 that shoots fine. Keep your powder dry and warm and it will last as long as you do.
Well after 35 years depending on storage the percentage of misfires goes up. That for non-corrosive priming componds. As for corrosive componds they last god knows how long for their civial war made ammo thats as good as the day it was made.
Rifleman 336
Corporate Stooge
Is there any advantage to vacuum packing it?
Yup. That removes any air and eliminates the need for dessicant. Pack it in bricks of an amount that you'd use in one 'sitting' and you should be good to go. I've got 2000 rounds of 7.62x54r packed in 80 round groups that might just outlast my lifespan.
Keep it out of heat and extreme cold and you will be fine. I have some ammo made in 1886 for a Steyr Model 1886 Straight Pull that fires like a champ.
Battling the Beast
There are some lead free primers being used that use aluminum compounds that oxidize and have a more limited shelf life, expected to be around 10 years. A specific example is FN's 5.7x28 SS195LF. For that reason I buy the non LF SS197SR for longer term storage.
That being said, as many others have posted, the vast majority of ammo will last decades stored properly.
I use GI ammo cans with the red to blue desiccant bead packs from ATG. I store all ammo and firearms in a closet with a powered dehumidifier running.
I've heard a rumor that this can cause some primers to pop out due to the difference in air pressure inside and outside of the casing when placed under a vacuum. I'm not sure if this is true or not, but just something I've heard.
If you are careful in vacuum packing ammo the primers will not pop out. Many rounds of various ammo will pop the primers if the vacuum is sudden. Plus many types of ammo are sealed with a varnish type substance which can create a very airtight environment within the casing. However even that seal is not perfect so a VERY slow pull on the vacuum is necessary and does work.
1 - 20 of 38 Posts
