This is a kit I bought from Harbor Freight!
I'd never done this before so here's the story:
It weights in at about 200 lbs and only cost me $270. I have to
The downside? I have to build it!
The next stage was securing the leaf-springs to the trailer. The guide was vague but I got the right stuff in the slots!
Once this was done it was time for the critical axle to be installed and clamped into place onto both leaf-springs with a set of U Bolts and steel plates. Then is was just a case of getting the wheels on.
I took apart one hub assembly to have a good scan about inside. The Oriental Factory people had pre-greased it but I added some more just to be certain.
Once the hub assembly was slid in I just had to add the crucial 'castle nut' flush then back it off 1/6 of a turn so the thing could spin freely.
The tools I used to get the hub cap off. You don’t have to remove the entire hub assembly though, unless you re re-greasing it, or wanting to mount it to the axle easily.
I almost forgot to put the cotter pin through the axle!
Wiring the cabling for the brakes and signal lights was a bit niggly but I got it done.
This is crimped and heatshrunk. Earlier I had tried soldering it with a Harbor Freight butane torch but it wasn’t fine enough and kept melting the adjacent wiring.
Got these boards for helping make the trailer bed and box.
Work on the boards and 2x4s for painting.
Wheel Bearing assembly
