Hello and welcome to SB!
Besides the specs listed, which are standardized, you can trust em imo.First problem is that I went on Amazon and found this huge table of specifications unknown to me.
What are the main characteristics I should care about?
and the second problem is that I could order anything from Amazon but how do I check the reliability on my own? That those specifications are not a lie.
a phone or radio test can tell you at a basic level if the cage is shielding electromagnetic radiation. so a fail on this test certainly tells you there is an issue and for that reason it is worth doing. I'm unaware of any test that can tell you the shielding will protect against a nuclear emp pulse or major solar flair, outside of a very expensive and complicated test lab environment, and still the results are theoretical.The phone test means just about nothing. See here for the reason:
My Ammo Can Faraday Cage Test.
I picked up a NVG case and wanted to test it's effectiveness as a Faraday Cage. (An NVG case is like a U.S. Military Ammo can with foam inside for protecting Night Vision Goggles.) I don’t have an isolated location where I can conduct actual EMP testing without frying the neighbors house and I...www.survivalistboards.com
I am not sure this test is valid. If you are inducing 10s or a hundred milivolts into the receiver of the radio it will pick up a signal however a few hundred millivolts will not damage your electronics. did they use a conducting gasket or copper tape around the edges? The idea here is to attenuate the signal. An ammo can will attenuate the signal especially if you sand off the paint and use an electrical gasket and copper tape around the edges. This will provide about 70 dB of attenuation. 3dB is half. 10 dB is reduction by a factor of 10. If my math is right, that will attenuate the signal by a factor of 10 million.The phone test means just about nothing. See here for the reason:
..just as they are all too quick to tack on the phrase "military spec" even though what they are selling is a POS.The specs may not be a lie - but they also may not apply.
Lots and lots of sellers just tack on something that looks good, but doesn't really have anything to do with the suitability for purpose.
Add to that the real difficulty in getting hold of hydrogen bombs to test with - and you see that there's little reason to put a lot of faith in the sales pitches.
No doubt there are people (military) who have done actual testing. I don't suppose it is in their best interest to make the info public or sell a "cure" on Amazn.
A fariday cage has no requirement for insulation. Ive never seen a full size cage that is ever insulated- and most have been through EMP simulators ( for a first arctic le test). Why does anyone think a sheet foam is going to block an electromagnetic signal, and if it did, why not build the whol box of foam?I play the odds. A perfect cage has a complete metal seal all round, and complete electrical insulation on the inside. A Behrens trash can with maybe a few pieces of metal tape over mini openings like around handles meets the "complete metal shell" standard. A good carefully done lining of soft foam meets the electrical standard. Then the can is in may cellar and grounded. I THINK that is good enough. I have some pretty expensive electronics like night vision in there.
If I thought I lived close to a place that might be a target, I would probably double my protection. A smaller can inside a bigger can, but I live in the middle of nowhere.
