1 - 20 of 41 Posts
IDK if this is the correct section but I know there are a lot of people with construction experience in this subforum.
I am in the middle of a project and have hit a major snag. The concrete floor has gone from 4-6" thick to 18"+ and it is TOUGH to get through! I am using a 120v jackhammer but it isn't cutting it for this thickness of concrete. I am moving about 1/15 as fast as I was on the 4-6" thick. This thick stuff is also the last of the concrete and back in a corner so it is REALLY tough to get at as I am standing below it making all of this really difficult.
So, can anyone suggest something else to help break this up? I thought maybe getting a concrete saw but IDK if that is going to do it. I figured that I could cut and chip, cut and chip... This won't be fun but I figure that it would be a method that will get it done.
Do any of you know of a better method? Explosives are out of the question lol:D:.
Also, this is in the laundryroom so any equipment must fit through a 32" wide door.
· Is back.
Depends. If it is general demolition; Possibly us a bobcat to get under the pad and lift it up to break it. otherwise you might have to get a jackhammer attachment for the bobcat, or the "jaws" for a backhoe. or you could just have fun and rent the biggest bulldozer you can find. ;)
Discussion Starter · #3 ·
I don't think a Bobcat is going to work. I need something to fit through a 32" door.
Similar to what Tankspridd suggested, I'd chain drill it with a masonry drill then hit it with the jackhammer. Like breaking large chunks of ice or shelf blasting rock, several holes in a row, then a large impact will split the target.
Discussion Starter · #14 ·
put the machine away jackhammer works sometimes but mostly makes holes. just lift an edge w/ pry bar and hit w a sledge hammer start from the outside edges. hope you dont have to much rebar in there
Do you have ANY idea how difficult 18" thick concrete is to break up!? There is nothing that will work besides a jack hammer (preferable attached to an excavator of some kind), cutting saw and maybe heat, but heat requires holes to be drilled or pounded and in that case just jack-hammer. If it were the 4" or 6" a 10-12' prybar might work.
1 - 20 of 41 Posts
