This is much like the list of power sources. If you have a source of water you would like to add to this, please do. I ask respondents to please post existing sources of water and not sources of water that will have to be installed. The idea for this list is to provide a list of sources of water when you need water in a hurry, primarily in an urban area. Here are my sources.
DISCLAIMER: If you get killed trying to survive using any of this information, don't come crying to me.
Use your head. Consider the cause of the SHTF before using water that may be contaminated.
#Mall and office decorative fountains - Inside a building and probably protected from contaminants. Open to the building air and typically not part of the water supply
#Refrigerated drinking water fountains - they have a small tank inside to store the cooled water.
#Water Heaters - Typically 40-50 gallons of water. Water can be removed using the drain spout on the bottom. Be sure to close all incoming valves prior to use to prevent outside water from coming in
#Sprinkler Systems in large buildings - The large pipes in these systems can hold literally hundreds of gallons of water. The larger the building, the more water in the system.
#Hot Tubs and Swimming Pools - These may be exposed to contaminants and will probably have a lot of chlorine in the water. Chlorine can be removed.
#Construction Sites - Look for large tank trucks. Often the water is not potable, bit it can be made potable.
#Public Fountains - May be exposed to contaminants, but often are not open to the public water supply except for filling
#Water and Amusement Parks - Exposed to contaminants and chlorinated
#Well Pressure Tanks - Typically hold about 20 gallons of pressurized water.
#Toilet Tanks - 1.5 Gallons per flush.
#Factories - Often factories will have large water storage tanks for storing water.
#Car Wash - Car Wash water heaters are often large capacity, sometimes over 100 gallons
#Coin Laundry Locations - Often have multiple water heaters, over 100 gallons
#Restaurants - Large water heaters
#Camp Grounds - It varies, but many camp grounds that are outside of public water supplied areas will have a large pressure tank and well.
#The obvious - lakes, rivers, ponds
#Office Buildings - Water coolers, the kind with the big, blue bottle on top
#Hand Pumped Wells - They do still exist. Many older homes still have them even though they are on city water. Leftover from another era.
#Medical Facilities - Raid the outside faucets.
#Vending Machines - Just because the power is out doesn't mean the machine won't give up a bottle of Dasani. Hit it with a large hammer!
#Bagged Ice Freezers - You see these at gas stations. Large, white boxes with a sloped front, often outside. By the time you get there it may filled with bagged water.
Remember, this list is a list of improvised and expedient water sources. Knowing the locations of water sources may save your life or the life of a loved one. Just because you have a zillion gallons and a solar powered well at your super secret squirrel BOL doesn't mean you will be able to get to it. Its always a good idea to know where to find water when you need it.
When adding to this list please keep it to improvised water supplies. Posting links to sources of solar powered well pumps and rainwater collection systems and the like have no place here. This is a list of IMPROVISED and EXPEDIENT water sources. Remember, people have died because they did not know where to find water when it was all around them.
Prior Planning Prevents **** Poor Performance. Have a plan in the event your original plan should fail.
