Hey folks, I've been kicking around the idea of building a belt driven generator. The more I look into generators the more I see they are not built for joe schmoe like me. They either are cheap Chinese generators that are constantly tearing themselves apart or HUGE industrial gensets. I don't need 20 kw or even 5 kw.
I think 2 kw sounds fine. Another issue is the lack of surge capacity. I want something that can power a 15 amp receptacle and start anything that will run on a 15 amp circuit. So i need a heavy flywheel. Those are things you just can't get on the market. So I am thinking of a car engine. I could buy a cheap lawn mower engine and run it slower and just buy a bigger one but a semi modern car engine could be had for the same price as a decent honda small engine. I got a decent idea on how to regulate it. Hoof governor or another home built design.
My question:
Would the gas consumption be better or worse?
I plan on running it at idle or a hair above and using pulleys or a gear box. Pulley would be better, i can redo the pulley if i want more power.
Thinking of using a geo metro engine. I read online idle consumption is .10 of a gallon of gas an hour. Only problem there is i can't figure out how much HP it would have. No AC or accessories so no extra power needed. I'd either remove the alternator or find the smallest one i can. Might use a small solar panel or charge it from my battery bank. I don't think a running engine requires a lot of power to keep it going.
The engine should have more inertia compared to a cheapo small engine so regulation should be smoother but could I add a flywheel weight to the shaft to smooth it out? I tried to figure the math on that but can't find anything on how big it needs to be. Technically it needs to store 1 watt of power roughly for an hour. In one second that would add a lot of surge capacity.
Anyone have experience in this?
My question:
