Hi all, I have been researching and messing around with a deep well pump design. It is made of PVC pipe mostly all off the shelf stuff. I must admit I have not stuck it down my 175 foot well yet. But it does work out of a 55 gallon drum with 200 feet of garden hose stretched up the hill and in to a tree.
It is based on the old Air-lift pump which is only good for short lifts. I just added a foot valve and a one-way valve in the pipe the water goes up. The pump is basically a PVC pipe inside a PVC pipe with two check valves. It will pump water with 125 PSI air or less. The beauty of this pump is it will last well over 20 years, can run dry without damage, and most of the moving and service required parts are above ground. Only 2 one-way check valve are at the bottom of the well, oh and some pipe.
I drew up a pretty good picture and then converted it to a GIF format so I can share it if anyone would be interested. Here is a web site where a similar pump is in use and or being tested.
http://openfarmtech.org/weblog/?cat=292
I am currently working on a Vacuum /Pressure pump that can drive this deep well injection pump. This drive pump uses an old recycled car engine flywheel and starter drive gear. The fly wheel becomes a bull gear that drives a connecting rod for a 16 inch stroke suction pressure pump. The theory is to just cause the injection pump check valves to cycle open and closed. Thus filling and emptying the pump. In so doing you force water up the water pipe and since you are forcing or pumping up water and not relying on suction you can pump water up hundreds of feet.
Let me know if you want more details, I guess I could create a set by step set of instructions. Note all parts were bought new at the local "chain" hardware store.
Katie
Katie
