I have built a few garden beds for my slice of the "American Dream." Here is a link to the plans that I used: Three raised bed designs by Joe Mooney
Thanks ForestBeekeeper, Brilliant Idea. Do you use solid blocks or the open ones with the void for concrete/rebar? Do you put anything in the void to make them weigh more? How high do you build? I had considered building with out mortar but was concerned about the blocks moving/shifting with the weight of the soil in them. I was thinking about leaving the ends of the beds open (4'wide by 10-20' long) so I can lengthen them if I need to and to run the tiller up into them when I want to "ammend" later on. What do you think of that idea?We use concrete block [8 X 8 X 16]
I have found that if I need to move them a year later, this is much easier.
Also if I think I need to re-mix the potting soil [add more sand or turn-in more manure, etc] it is pretty easy to do using my tractor loading bucket. Just move the blocks on one side, and my loading bucket can scoop out all of it, re-mix, etc.
Also put down a couple payers of old feed bags on grade before you setup any raised bed. This stops plants that are below grade from coming up into your bed.
I use the blocks with the holes. We have never seen any problems of them being to lightweight.Thanks ForestBeekeeper, Brilliant Idea. Do you use solid blocks or the open ones with the void for concrete/rebar? Do you put anything in the void to make them weigh more? How high do you build? I had considered building with out mortar but was concerned about the blocks moving/shifting with the weight of the soil in them. I was thinking about leaving the ends of the beds open (4'wide by 10-20' long) so I can lengthen them if I need to and to run the tiller up into them when I want to "ammend" later on. What do you think of that idea?
