I have this one, I think it was $70 at oriellys a few years ago. Well worth the money.https://www.amazon.com/gp/product/B000L9AD2U/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Buy one of these..... don’t go cheap
^^^^^THIS!https://www.amazon.com/gp/product/B000L9AD2U/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Anyone have the harbor freight 150 psi compressor or another good brand. Seems it would be a good idea to carry one in truck
With converted AC compressors it always seems you get a ton of oil bypass if the compressor is well lubricated enough to stay alive. If you cut back the oiling they don't last very long. Even with multiple oil/water separators the tires ended up coated in oil.I've had issues with every one of them. Best one I've found so far is the dual pump unit from ARB, the CKMTA12. I've had two of them for years now, terrific pumps. One stand alone, and one is in the carrying case with the tank. I've had to use two hoses end to end to reach the rear trailer tires, but other than that no issues. I've burned out one Viair and one master flow so far, and uncounted Harbor Freight and similar units. Better than a 12v is just run an engine powered air pump, pretty easy to modify York AC pumps to do that.
I made one like that because if you roll the bead you can need a large inrush of air to get it seated again. Most small non-tank compressors can't provide the necessary flow rate. Just pump up the tank until the pressure relief pops and then plug into the tire. Also have an inline pressure adjuster that allows me to set the inflation pressure so you don't have to keep checking.I have this one.
https://www.amazon.com/Puma-Industr...or&qid=1581348931&s=automotive&sr=1-2-catcorr
It can be separated and you can mount the tank under the vehicle and the compressor motor in the engine bay. It works awesome. I can refill a 35 inch tire from 12psi to 30 psi in about 3 or so minutes.
It will also run an impact just enough to remove lug nuts.
