Do I need to block the sewer line? - Page 3 - Survivalist Forum
My thoughts on INCH kits Jerry D Young Disaster Preparedness General Discussion 99 08-11-2019 10:58 AM
Browning Expands Black Label Pistol Line AllOutdoor.com AllOutdoor.com 0 04-26-2017 08:00 PM
Survival use. What lbs fishing line.. scoutrifleshooter Boating and Fishing 22 01-29-2017 07:52 AM
Buying a compass roof_top_eagle Disaster Preparedness General Discussion 42 12-14-2016 08:24 PM
Benchmade dropping the entire HK knife line Inazone Knives, Swords & Axes 5 11-09-2016 07:10 PM
Old 08-03-2017, 09:13 PM
surfcast's Avatar
surfcast surfcast is offline
SI vis pacem,para bellum
There are check valves, for the main sewer line . Look on line ,or go to you local plumbing supply.
The Following 3 Users Say Thank You to surfcast For This Useful Post:
Old 08-03-2017, 09:31 PM
Ricekila Ricekila is offline
I love this forum
Either get a manual one -- or go fancy ?
http://www.homedepot.com/p/4-in-PVC-...3904/100144734
Old 08-03-2017, 10:13 PM
augoldminer augoldminer is offline
Hunter
Location: high desert calif at the edge of the big empty
A friend does septic line work and he plugs lines with car or truck Suspension Air Bag.
The airbag can be put in and air will inflate it till it seals the line.
And he found there cheap when he gets them from a auto wreaking yard
Old 08-03-2017, 10:19 PM
I love this forum
Me thinks we're being played ?
https://www.survivalistboards.com/sea...rchid=39947673
One question then a 3 year absence ?
Old 08-03-2017, 10:52 PM
Jim in Illinois's Avatar
Jim in Illinois Jim in Illinois is offline
VIP Member
I am a retired sewer and water operator. I have seen hundreds of sewer backups. Most were caused by high flows during storms due to illegal connections to the sanitary sewers. People often connect their sump and roof drains to the sewer. They also flush things they shouldn't or even open manhole covers to get rid of things. We have found mail boxes, bags of puppies, 2x4s, car parts, and just about any thing that could fit through a manhole cover blocking sewers.We even had one plugged by a 4' long 8" diameter dildo.
A plugged sewer can develop considerable pressure so the only sure way to prevent backups is a gate valve on the line to the house. On sewers with bolt down covers I have seen the pressure lift the manhole top section of a manhole out of the ground.
The Following 5 Users Say Thank You to Jim in Illinois For This Useful Post:
Old 08-03-2017, 11:16 PM
Vonfatman Vonfatman is offline
feeling my age
a good question is a good question
bob
Old 08-04-2017, 07:50 AM
Birddog15's Avatar
Birddog15 Birddog15 is offline
Member
Jim in Ill. - That's a little discouraging! I've wondered about head pressure, but hoped it wouldn't get too bad. I worked in construction for many years so I have a couple of test plugs I figured I could use if needed. But, lifting the assembly out of the ground!!! Yikes. A little friction from a test plug isn't going to hold that back.
Luckily, it is relatively flat around here, and even though I am at a "lowish" spot in my neighborhood, the highest spot is probably only a few feet above me.
I hate gate valves that don't get used frequently, due to their habit of seizing up. I am thinking about a big PVC ball valve?
Back to the drawing board.
Old 08-04-2017, 08:43 AM
VIP Member
I have seen test plugs blow out a few times but they usually work. Gate valves need to be exercised or they will seize, their were about 7000 in the system I was in we opened and closed them twice a year and recorded the turns each way. Ball valves will work but they can jam to, we had them in a lot of lift stations we exercised those monthly. Anything in sewerage needs a lot of service or the solids in the sewerage will jam it.
For a home you will have a 4 or 6 inch service connection exercising those is not too hard. We had valves as large as 48" those can be quite a workout.
The Following 3 Users Say Thank You to Jim in Illinois For This Useful Post:
Old 08-04-2017, 08:52 AM
I love this forum
Originally Posted by Jim in Illinois View Post
Gate valves need to be exercised or the will seize
Every 6 months or so --
Close & open valves under your sinks - change smoke detector batteries - change your oil - get back lent out tools - reverse blow out your dryer vents - twist the sewer back-up valve --
Old 08-04-2017, 09:25 AM
Sky1950's Avatar
Sky1950 Sky1950 is online now
Dios y Tejas
I have seen test plugs blow out a few times but they usually work. Gate valves need to be exercised or the will seize, their were about 7000 in the system I was in we opened and closed them twice a year and recorded the turns each way. Ball valves will work but they can jam to, we had them in a lot of lift stations we exercised those monthly. Anything in sewerage needs a lot of service or the solids in the sewerage will jam it.
Jim.
thanks for mentioning exercising the Gate Valves. I forgot to mention that in my post. A check valve on these gravity systems is like playing Russian roulette with an automatic in my opinion. Heck, I dont even call them to be used in those rare instances of encapsulated storm runoff control backup, much less sanitary sewers.
I never specified Ball Valves in any of my designs as I thought these were primarily used for small diameter private residential water. And thinking about it now, I cant remember why I never called them out. The industry standard down here is almost always a gate valve.
PS... I always recommend to homeowners (even though I only do commercial and larger designs), to always use a 6" (not 4") sewer discharge from their house. Not because of heavy flow, but because someone will always put stuff in the toilets that dont belong there, clogging the line.
The Following 2 Users Say Thank You to Sky1950 For This Useful Post:
Old 08-04-2017, 09:52 AM
I love this forum
6" = so the turds dont tumble
Old 08-04-2017, 10:00 AM
manimalist's Avatar
manimalist manimalist is offline
Originally Posted by Idyllwoods View Post
I plan on bugging-in and my concern is the sewer might backup into our house. Does anyone know of a way to block the main sewer line to prevent any backup? Or, is there any info to show this would not be necessary? Thanks all!
Tampons.
Old 08-04-2017, 10:09 AM
I love this forum
Originally Posted by manimalist View Post
Tampons.
Ever sweat a joint where there was a way to pull the string later
Always kept a few in the pluming box
Old 08-05-2017, 09:12 PM
Birddog15's Avatar
Member
Yup, mine is a 4 inch pipe. Old cast iron in the house, not sure what is out in the yard. Thanks for sharing your knowledge with us Jim!
The Following User Says Thank You to Birddog15 For This Useful Post:
Old 07-15-2019, 08:49 AM
MikThundercloud MikThundercloud is offline
NE TN Disaster Mik
Sewer systems come in a wide varieties. Plumbers can do strange things to make it work.
One simple, but potentially VERY MESSY, but cheap solution I have on standby is a rubber plug that will fit into my 4 inch main drain line and a screw fitting to an extended cleanout.
In the event of a major backup, like during area flooding, etc... I can open my cleanout, insert the rubber plug downstream to isolate me from the outside system and attach the extention pipe to make it easier for me to redirect my own waste flow to an alternate disposal system (worm bed composting).
While this is only a short term fix, it saved my wife from a repeat of the sewer backups we had during previous floods coming into the bathtub... We also have a portable toilet bucket system for SHTF situations so we minimize our waste outflow when needed.
You have to look at how your system is set up and find solutions that might work.
The Following User Says Thank You to MikThundercloud For This Useful Post:
Old 07-15-2019, 09:09 AM
wldwsel wldwsel is online now
I have a check valve on my "dosing tank", which is downstream of the septic tank. The septic fills, solids to the bottom, liquids to the dosing tank. When the pump in the dosing tank turns on, via a float switch, it pumps the liquid to the drain field, which is several feet higher than the house (which is why I had to have the dosing tank.
I would think you would need a check valve, but the size of pump you would need to push you stuff downrange verses my pump (one house worth of liquid) might make the hole thing undoable. If you would need a very large diesel engine to force your stuff out (and keep other's stuff from coming in, you might5 as well build your own utility.
WW
shoot straight - stay safe
Old 07-15-2019, 09:47 AM
cleatis's Avatar
cleatis cleatis is offline
The end is,,,,,
https://www.supplyhouse.com/Red-Flag...a2a22e7691f679
Price is subject to your area, go find one at the hardware store near you.
Add one of these between 2 flanges will work also.....(see picture)
Old 07-19-2019, 10:54 AM
lasers lasers is online now
I think a butterfly valve like you pictured would be a constant problem on a sewer line. I think it would plug up every time someone used more than a few squares of toilet paper.
A gate or ball valve will allow the pipe to mostly be open with maybe a bit of obstruction on the edge of the pipe. A butterfly valve will always have the center of the pipe blocked and will catch all sorts of debris.
The Following 2 Users Say Thank You to lasers For This Useful Post:
Old 07-24-2019, 10:47 PM
Billofthenorth Billofthenorth is offline
Bipedal primate
In my neighborhood with old houses most approaching 100 years old, a sewer system just as old and a city gov't not too efficient we get plenty of back ups. In fact the system was designed that way, to back up into the basements when the system couldn't handle heavy rains. At least that's the way it has been explained to me. When the city demolishes derelict and abandoned houses, they plug the drain with cement. That's a pretty permanent way to do it but in a more or less permanent SHTF scenario it beats a basement full of...stuff. I've always assumed I would dig an outhouse or build a septic system if necessary, assuming the collapse of local municipalities and national authorities etc.
Old 07-29-2019, 09:39 PM
edprof edprof is offline
Prepared
These posts make me glad I'm on a septic tank.
The Following User Says Thank You to edprof For This Useful Post:
Tags
bug-in, sewer
