The Multicam Adventure - my trial and error project - pic heavy - Page 2 - Survivalist Forum
Black Multicam...Your take? mattmuttsmith Military Weapons Forum 51 10-10-2016 11:36 PM
Multicam Backpack scon86 Wilderness Survival, Hiking and Camping Forum 24 12-02-2015 04:32 PM
New Multicam patterns are here.... PapaWhiskyBravo Urban Survival 57 11-11-2015 04:52 PM
We're to buy multicam BDU? bobbydeadup Looking for - want to buy 19 10-14-2013 04:45 PM
multicam project ideas. TimHaar DIY - Do It Yourself 1 04-15-2013 04:31 PM
The Jennings Project.. Pic Heavy run2daHillz Pistol and Revolver Forum 7 10-16-2012 11:11 AM
A family project.....(pic heavy).... Smudge Wilderness Survival, Hiking and Camping Forum 8 01-22-2012 12:19 PM
Multicam - Your thoughts twyggy Wilderness Survival, Hiking and Camping Forum 9 11-12-2010 06:39 PM
Poormans forge trial and error........ Smudge Knives, Swords & Axes 30 05-13-2009 09:53 PM
Old 08-18-2011, 10:31 AM
juju151 juju151 is offline
Newbie
These are the colors that I used.
I used Krylon and Rustoleum paint in the can. All of the flat camo colors I could find at WallyWorld, Home Depot
and Ace Hardware, plus I got some flat white, satin hunter green, and gloss yellow (which was the only yellow
I could find). I turned the cans upside down and put a little weight on them until there was almost
no air coming out. Then when you turn the can right side up, the paint comes out in a pee stream
instead of a mist. The Rustoleum paints seemed to still spray upside down, so they didn't work too
good doing that. Anyway...after letting most of the air out, I put one of those spray can handle things
on the can, and put a tie strap around the trigger to make it spray without holding the can. I did this to
spray the paint into mason jars. So all of my colors were in mason jars and I could mix colors as I wanted
and then put it into my airbrush jars. I wanted to use the airbrush to have a little more control of spray output.
You can get an airbrush pretty cheap and to me it seems to make a big difference in your paint finish.
You could do the same thing with spray cans, but you would just have to do a little more masking to protect
the surrounding areas from overspray.
You can see some positive stencils on the cutting board that was left over from the 1st rifle.
I will use these after applying the base colors. You can also see how messy this project is by looking at
my workbench!
:D
Base coat applied...Light O.D. Green and Tan.
Leftover positive stencils stuck on randomly around the rifle, then misted with a mixed medium green
and medium brown here and there...
Results after pulling positive stenciles off...
Now it's time to start with the negative stencils...At the top of the picture you can see the stencil drawn, in the middle is the
positive left over from cutting it out, and at the bottom is the negative that I will be using to spray on.
Top of the picture is it stuck on the stock, middle is after it was sprayed, bottom is with the stencil removed...
Ok...here is the same stencil that was shown above being reused on the opposite side of rifle, on the upper receiver.
Notice because of the odd contours of the receiver, I had to cut the stencil and add a couple of little filler pieces.
But the same process here...stick, spray, remove.
One more stencil drawn and cut...
Stick, Spray, Remove... :lol:
Same stencil as above, being reused on the scope...and a small positive stencil stuck in the center.
Continued in the next post...
The Following 8 Users Say Thank You to juju151 For This Useful Post:
Old 08-18-2011, 10:33 AM
Newbie
I already painted the mags for this one when I painted the other rifle, and all the mag base colors were done pretty
much the same...so the left upper side was done in medium brown and the right side was done in green. So I wanted
to paint the magwell on this one so that the mag colors would match up, and not abruptly change and have a straight line
where the mag and magwell meet. So I cut a strip stencil out and used the negative part on the brown side, and the
slightly modified positive part on the green side...and just wrapped them around the magwell. Here is the stencil drawn
and cut...
Here is the negative and positive parts wrapped around the magwell...
So now all 10 mags that I painted will work in either rifle and look pretty much the same. Here is the result, showing
how the mag colors meet up...
Here it is about half way done...Some more dark brown, off white, and medium brown highlights still need to be put on...
Here it is done, after the highlight colors have been added...
Here's both of them together...
Hope this helps...GOOD LUCK!
RC007's Avatar
RC007 RC007 is offline
Member
Very nice job. Must've took alot of your time.
The Following 2 Users Say Thank You to RC007 For This Useful Post:
Old 08-18-2011, 10:45 AM
Grevlin's Avatar
Grevlin Grevlin is offline
Gone Galt
Not really...spent an afternoon so far. Hit the store, 30 minutes drawing and cutting the stencils, 30 minutes prep time, and then maybe 3 hours on the cardboard sample. I waited a while between layers and free-handed everything.
It will take a lot longer on the actual rifles and gear because I will let each layer sit like 6 hours, and then all the gear will sit for like a week to make sure its good and set.
Old 08-18-2011, 02:13 PM
Grevlin's Avatar
Gone Galt
I found two new colors at Home de-pot
Working on sample Ver 2.0 now
Pics and review to come
Old 08-18-2011, 06:46 PM
Cryptkeeper's Avatar
Cryptkeeper Cryptkeeper is offline
i would get a toy rifle and pratice on it at least do a couple of differnt patterns and such until you feel comfortable about doing your weapon plus this will let you see how it will look.
side note : i would lean toward lighter/softer colors like multicam is
The Following User Says Thank You to Cryptkeeper For This Useful Post:
Old 08-18-2011, 06:52 PM
infinityshock infinityshock is offline
This is a great survival forum
if you want a flat/matte color but only have gloss colors available go over the dried paint with fine grit sandpaper to take off the shine.
Old 08-18-2011, 07:07 PM
Grevlin's Avatar
Gone Galt
I got a few new colors and I think I got it dead-on, but one had a faulty nozzle and ruined my sample.
I may try another tomorrow, or this weekend.
Old 08-19-2011, 03:06 PM
Grevlin's Avatar
Gone Galt
Day 3: BY GEORGE, I THINK I GOT IT!
So I have Sample 2, and I think I got it. Check out the pics
My original color #1 became my new #3 (it had a little green in it) and I found new colors at Home de-pot for #1 and #4 - and I think its dead on.
I have my painting style down, and I'm half way through painting a plastic toy shotgun (don't ask) Pics to come!
New color List-- Lined up like in the pic:
Base:
1. Light brown (Home de-pot)
2. Darker brown (Walmart)
Middle:
3. A sort of light pea-green (WM)
4. A avocado green faded into (Home de-pot)
5. A darker green (WM)
Top:
6. The really light tan (WM)
7. The really dark brown (WM)
Total cost so far: About $60 and I should get through most of my gear with it.
Enjoy!
Name:	1 - Can you find it.jpg
ID:	54602   Click image for larger version
Name:	2 - there it is.jpg
ID:	54603   Click image for larger version
Name:	3 - Sample 2 close up.jpg
ID:	54604   Click image for larger version
Name:	4 - The final color set.jpg
The Following 9 Users Say Thank You to Grevlin For This Useful Post:
Old 08-19-2011, 05:07 PM
Grevlin's Avatar
Gone Galt
Day 3 - Part 2
I had an orange toy shotgun lying around...again, long story. It looks like the pattern works well on the curves as well.
I may actually try my Ka-Bar kydex sheath this weekend
Name:	5 - Sample SG Shape.jpg
ID:	54617   Click image for larger version
Name:	6 - Sample SG Shape - close up.jpg
ID:	54618   Click image for larger version
Name:	7 - Sample SG Shape - alone.jpg
The Following 7 Users Say Thank You to Grevlin For This Useful Post:
Old 08-19-2011, 09:10 PM
Crutch's Avatar
Crutch Crutch is offline
Limpin to safety.
Grevlin, anyway You might consider teaching this to my group?
I think this is totally bad ass.
Also... we are doing another range day... so if you ever decided to join us..
The Following 4 Users Say Thank You to Crutch For This Useful Post:
Old 08-19-2011, 09:29 PM
Grevlin's Avatar
Gone Galt
...did you say range day (I have all kinds of new family members )
Maybe it's time to re-join the land of the living, and showing your group would be a pleasure. The only real hard part is finding the EXACT color combination. I have 2 stores and exact colors from each to get it to work.
I like multicam because of how it sort of adapts to it's background - and I don't want 4 different sets of gear for different settings.
That said, I think multicam for general, regular woodland for night, and something with more browns for "winter" would be the wish-list for our area. But that just gets silly. I may experiment with custom sniper veils and some camo add-ons.
The Following User Says Thank You to Grevlin For This Useful Post:
Old 08-19-2011, 09:48 PM
Doc_Shane's Avatar
Doc_Shane Doc_Shane is offline
Garbage Collector
Rocking thread............... I am a fan of multicam.
Grevlin awesome adventure
Juju amazing work, straight badass look on the rifles
The Following 2 Users Say Thank You to Doc_Shane For This Useful Post:
Old 08-19-2011, 10:12 PM
sardog's Avatar
sardog sardog is offline
All bark, no bite
Truly a work of love and art ! I am very impressed
The Following User Says Thank You to sardog For This Useful Post:
Old 08-19-2011, 10:17 PM
touchdown!!! on the colors i think some of your patterns need to get smaller/thinner, they looked a bit big on that toy but it may be the size of the toy . but it looks like a perfect match give us a list of your all your colors now and where you found them.
boy that toy blends in real good with the tarp its a good job on matching the pattern of the tarp.
if you got time take the toy outside and see what it looks like in brush,and leaned up against an oak tree...ect
once you actively committe to painting your weapon.start a new thread and give us a play by play.exactly how you applied each color,in what order ,how many stenciles...ect. show pics from beginning to end, each and every step
The Following 2 Users Say Thank You to Cryptkeeper For This Useful Post:
Old 08-19-2011, 10:45 PM
Boonie's Avatar
Boonie Boonie is offline
survivalist in training
I think I'm going to kick my son out of his room to paint it in multicam (won't tell him that part) and tell him he can't see it until I'm done so it will be a surprise. He'll be the envy of all his friends.
Being able to paint like that would seem to be a really awesome SHTF skill to have! Great going guys and thanks for posting!
The Following 3 Users Say Thank You to Boonie For This Useful Post:
Old 08-19-2011, 11:01 PM
isnt there a clear coat or a sealer you can cover the paint to help protect it from scratching & peeling .
does these paints keep it from rusting?
Old 08-19-2011, 11:05 PM
Grevlin's Avatar
Gone Galt
I'm pretty sure it protects against rust unless you get a good deep gash that digs into the metal.
Clear coat - not sure, I want to see how this first batch holds up. And I need it really really NOT gloss
Old 08-20-2011, 10:39 AM
Grevlin's Avatar
Gone Galt
First Gear Project: Ka-Bar Sheath
(I feel like a little Elf - making my own toys )
Color #1 Light Tan
Color #2 Darker Brown
Color#1 on back
Color #3,4,5 - Olive, Avocado, and darker green
Color #6 and 7
On "The Wall"
Close-up
By itself
Name:	1 - Color #1.jpg
ID:	54632   Click image for larger version
Name:	2 - Color #2.jpg
ID:	54633   Click image for larger version
Name:	3 - Color #1 on back.jpg
ID:	54634   Click image for larger version
Name:	4 - Color #3 4 and 5.jpg
ID:	54635   Click image for larger version
Name:	5 - Color #6 and 7.jpg
ID:	54636   Click image for larger version
Name:	6 - on wall.jpg
Name:	7 - closer.jpg
ID:	54638   Click image for larger version
Name:	8 - by itself.jpg
The Following 12 Users Say Thank You to Grevlin For This Useful Post:
Old 08-21-2011, 12:02 AM
Boonie's Avatar
Originally Posted by Grevlin View Post
Close-up
By itself
Now, I really think that's just awesome!
The Following 8 Users Say Thank You to Boonie For This Useful Post:
