DIY Bug Out Vehicle build - Page 7 - Survivalist Forum
Bug Out Bag Test Ideas?? Lewis99 Disaster Preparedness General Discussion 13 12-01-2017 12:48 AM
DIY Body Armor for 5.56 Jonaz15 DIY - Do It Yourself 15 07-30-2017 06:55 PM
Winter Wilderness Bug out unknownprepper Canada 24 02-04-2017 10:36 AM
AR build decision making. COharbinger Military Weapons Forum 27 11-08-2016 08:12 PM
Bug out vehicle Barbender DIY - Do It Yourself 11 10-18-2016 05:20 PM
Old 07-17-2019, 04:39 PM
daddyusmaximus's Avatar
daddyusmaximus daddyusmaximus is offline
Retired Army
Guess who has motor mounts, and shock towers welded in?
Well, that happy feeling didn't last long... Guess who's brain damage, coupled with the inability to think in hot weather caused him to have the guy weld the motor mounts in the wrong place?
Having a TBI is not fun. I'm always forgetting things, losing things. I took off the rubber isolators and bolts, but to prevent me from losing them, I put them on the bolts... Now the guy shows up to weld, and I position the mounts without the rubber... He leaves... I remember the rubber... the engine sits too high with them, or just right without, but then it's mounted solid. I try to put them in, and the holes don't even line up. I remember from when I had the tub on, I should have room, but I really didn't want it that high anyhow. There is another issue...
The Jeep didn't come with this powertrain combo, and I had used the original trans mount (a new one) just to locate the engine in the frame. This places it in the correct place (front to rear) but a bit too high for good drive line angles.
So now I have a new plan... I have to modify the motor mounts on the engine block. Cut off the flat part on the bottom, and have it welded to the top, lowering them over the rubber isolators. Also, I don't need 4 inches of room between the transfer case and the skidplate, so I plan to have a machine shop remake me one bracket (red arrow) 1.5" shorter.
It's in for now, but it won't be in for good, for a while... I just don't want a complete fabricated solid mounted home made welded in set up like it had in the CJ5 it came out of.
Shock towers came out better. the tops are all perfect.
Rear.
Front.
Only problem here is the lower mounts on the left front are not in line properly, but they can be tweeked easily enough...
Last thing I had him do was a couple of little brackets I found in my scrap pile for my tire carrier. I needed a way to lock it open so it wouldn't swing back, and forth when I was using it. Now I can just open it, and drop a bolt or pin in there to lock it in place. I loved the LOD bumper when I looked at it online, but they didn't have a way to lock it open, and I didn't notice this at the time I ordered it. Problem fixed.
The Following 2 Users Say Thank You to daddyusmaximus For This Useful Post:
Old 07-17-2019, 06:04 PM
Retired Army
One other thing I've noticed that will require attention... the longer YJ springs makes for very tight clearance on the big 20 gal fuel tank I took off the CJ5. I have about 1.5" of rearward movement before the pumpkin gets into the skid plate...
I can't have nothing nice...
This is with the tub on, but nothing in the tub. Those shackles are gonna flex more than that, so I'm gonna have to think of something... I couldn't use the CJ7s fuel tank. Way too rusty. I'm thinking maybe just put a cut out in the front of the skid plate, then a trans tunnel like depression in the front face of the tank about 3 inches deep...
Old 07-17-2019, 06:46 PM
tedlovesjeeps71's Avatar
tedlovesjeeps71 tedlovesjeeps71 is offline
Move the axle forward a fuzz??
Old 07-17-2019, 10:29 PM
4X4's Avatar
4X4 4X4 is offline
Basket of deplorables
I don't know if you want to turn the CJ into a 2 seater, but you can put the fuel cell where the rear sets very easily. Many do it to open up a lot of clearance over the rocks in the rear. There are some options for custom fuel cells but then again more money. You will really like those YJ leafs when you get everything moving they will completely change the entire ride giving you a ton more articulation. I was trying to brainstorm something for your shaft pinion angle due to the motor mounts. I'm not really sure there is any good solution other than resetting the motor mounts without spending a lot of money on your rear end.
The Following User Says Thank You to 4X4 For This Useful Post:
Old 07-18-2019, 12:15 AM
Retired Army
My spring perches don't have the extra holes to move the axles, but they do have room to drill holes, and the top plates have the holes. That would give me about an inch, and a half.
Old 07-18-2019, 12:25 AM
Retired Army
The Jeep will have a single seat. There will be a dog box where the passenger seat goes for my service dog to ride in. Similar in concept to what I had in the old CJ5, but better executed.
The fuel cell, however cannot be brought up into the cabin, as I will be needing that space. We will be living out of the Jeep on our travels.
The Following User Says Thank You to daddyusmaximus For This Useful Post:
Old 07-18-2019, 07:15 AM
4X4's Avatar
4X4 4X4 is offline
Have you considered a hi-pinion differential? You could probably pick one up for around $1200 but then again more money. In the end you might still need to do more modifications up forwards to accommodate everything. I may be wrong but unless you are able to relocate those motor mounts it's going to be more of a pain than it's worth. In truth I wouldn't begin to know to ensure the drive shaft harmonics would be properly set.
Edit: I was thinking you might look into the older 12 gallon CJ-5 tank instead of the 20 gallon. It might just give you the necessary clearance you need? Without a saddle tank under the drivers seat you might not get the mileage you want but it's easily enough solved by carrying a little extra fuel you would have had on board anyway.
Old 07-18-2019, 10:42 AM
Thereís no reason you canít run the tank. Move the axle forward a bit then reset your drivetrain mounts to maximize optimum angles for drive shafts.
Old 07-18-2019, 11:30 AM
NCalHippie's Avatar
NCalHippie NCalHippie is offline
There is a place called 'High Angle Driveline' but I'm not sure if they are currently open. Their building burned to the ground in the Camp Fire but I think they are still in business.
http://highangledriveline.com/
The Following 3 Users Say Thank You to NCalHippie For This Useful Post:
Old 07-18-2019, 12:00 PM
Retired Army
New diffs are out of the budget. Way out. New housing means new gears, new shock mounts, (that I just had welded on) new brakes, new whole bunch of stuff... So much other stuff to do.
Not going with no tiny little 12 gallon tank either. I'll be traveling all over the country in this vehicle. A small divot out of a 20 gal tank will still give me maybe 17 gal give or take... Plus I'll be carrying extra fuel with me that just wasn't shown in the other photos..
I would love to look into a saddle tank under the driver's seat. Though that was never a thing in a CJ7 I like the idea of more fuel. They don't have that handi little place to mount an external fuel filler like the CJ5 does.
Old 07-18-2019, 05:58 PM
4X4's Avatar
4X4 4X4 is offline
If you look right about where the handle of your cane is is a really good and easy spot to mount the fuel filler. If you like I can send you a PM of what I did with mine and how it's mounted. I have a 7 gallon auxiliary tank under the driver seat.
Old 07-18-2019, 07:28 PM
That's the old "donor" Jeep. His current best upnis a CJ7 so no fuel delete recess. It could. Be done, but one would have to be very creative on how they ran a filler.
Old 07-18-2019, 08:49 PM
4X4's Avatar
4X4 4X4 is offline
Well color me silly, that's an oops moment! Thanks for pointing that out, I guess I wasn't paying that close of attention this morning when I saw the picture as to which Jeep it was....
Old 08-22-2019, 07:45 AM
Retired Army
I have not been spending much quality time with the Jeep as of late. The heat tends to kick my ass as I have had heat exhaustion several times in the past, and heat stroke twice. Also I thought my shoulder wasn't healing well from the surgery, but as it turns out it's my nerve damage from the IED that has been giving me fits. Same result in that my left arm hasn't been much use to me. I was able to correct one problem that I didn't like. The transmission sitting up too high. I designed a very short (half inch) box mount to replace the tall (two inch) zig-zag stock mount and had it welded up at a local machine shop.
A cut out in the side allows me to reach in and hold the center bolt with a wrench to tighten it.
The bolts drop through holes in the opposite sides big enough for the bolt heads. The transfer case sits at a more natural height, though with the SOA lift I will need to trim the skidplate for front driveshaft clearance at full droop.
Old 11-16-2019, 04:28 PM
Retired Army
Well, nothing has got done on the Jeep all summer. Money is always tight during the summer because my wife is a teacher's aid, so no paycheck. Also my shoulder is NOT healing from the surgery I had back in the spring... I have just started my third round of physical rehab with it. The VA keeps telling me the surgery went well, and that it's useless to even get a new MRI for 1 year, because it will just show abnormal anyway... They say it's inflammation from the surgery. I've had 2 previous shoulder surgeries... they healed much quicker.
Anyhow, I'm getting ****ed sitting around, so I decided to start in on the axles. Well, first I took out the fuel tank. No photos, but I don't like how close the pumpkin is to it with the YJ springs, so I'm gonna get a 2" tunnel put in the front edge of it kinda like a transmission tunnel, to give it some room.
First thing was to get one of the axles out. I decided to do the front one first. I lifted up the frame with the engine hoist,then worked the axle out from under, and onto a set of rollers.
I have too much crap in the garage, so I decided to use the Jeep itself as the workbench for the axles... I rolled it around to the rear, then hoisted it over the rear frame rails. Using double layers of plywood, I set it on jack stands on the tail of the frame, and strapped it down.
I set to work soaking every nut I could find with PB Blaster, and started in on one side. Being as my shoulder isn't up to snuff, and I haven't been able to stand long periods for years, I didn't get far, but I did make progress, so I'm good with that. I got one side brake caliper off, one Dodge truck automatic hub out, and that's where I got stuck. I stared in on the cotter pins, but the first one I came to was a PITA, and I decided to let it soak,and just call it a day. Just for fun, I tried the other side... pin came right out...
Old 11-16-2019, 07:29 PM
4X4's Avatar
4X4 4X4 is offline
You have probably already thought about this but what about doing a spring over conversion with a U-bolt reversal kit to give you a little more room for the third member? If not that maybe a couple add-a-leafs?
Old 11-17-2019, 07:41 AM
Retired Army
You're right. I have. Go back to the earlier posts, and you'll see that this is a spring over, and the U-bolts now face up. Problem is I've changed to YJ springs to get a softer ride on the tore up discs in my back, and neck. (they will also flex better) The YJ springs, being a bit longer set the axle back just long enough to put it real close to the tank, that is an aftermarket 20 gal one I took out of the CJ5. (same one I got the running gear out of) However, the CJ5 was running stock springs. Not so easy combining CJ5, CJ7, parts, Dodge truck axles, and engine, and International transmission into one vehicle, but I'm working with what I have...
I also have a 2000 Mitsubishi Montero Endeavor that I considered tearing up to get the drivetrain. I love the transfer case on that thing. It can be two wheel drive, all wheel drive, or 4 wheel drive. However, the little V-6 is pretty damn weak, and has 272K on it.
Old 11-17-2019, 07:43 AM
Daddymax, I feel your pain. Dealing with the VA is mindnumbingly frustrating. If you have health insurance Iíd suggest you try and go through that.
I spent all day yesterday riding a jackhammer and my body is very unhappy. If I had to wait for the VA it would be 6 months to a year before I got any relief. It sucks.
Good call on letting things soak and not pushing it. Sometimes the little things like cotter pins or brake fittings can cause huge headaches.
Old 11-17-2019, 09:47 AM
4X4's Avatar
4X4 4X4 is offline
I see, I was trying to picture how close to the tank that third member would be and why it's doing that. I'm putting the YJ springs in my CJ for better comfort and avoiding axle wrap due to the torque from the gearing and 350 under the hood. I don't believe I should run into that issue as I have a aftermarket 12 gallon tank. Biggest issue will be where to get the best spot in mounting the spring towers.
Hope you are healing up quickly enough. Not fun being all stove up especially with projects over your head.
Old 11-17-2019, 12:07 PM
Retired Army
One thing about being U S Army retired/disabled, I may be half cripple, but I've got nothing but time... The only real projects hanging over my head is the "honey do" list.
