Draw weight on crossbow - Page 2 - Survivalist Forum
Barnett Compound recruit crossbow vs recurve recruit crossbow Jake8313 Primitive Weapons, Bows and Crossbows 6 05-13-2015 09:15 AM
How to Find the Right Draw Weight For YOUR bow AllOutdoor.com AllOutdoor.com 0 11-17-2014 06:30 PM
Fat weight vs Gear weight fixesstuff Wilderness Survival, Hiking and Camping Forum 50 04-23-2014 07:27 AM
Longbow length and draw length (longbow for 31" draw) TheWoodsman Primitive Weapons, Bows and Crossbows 1 09-24-2012 04:13 PM
When to draw and when not to draw? warhawk-77 Firearms General Discussion 5 07-24-2012 02:33 PM
draw-loc or in-line crossbow lastoftheloaners Primitive Weapons, Bows and Crossbows 1 05-28-2012 10:47 AM
What point to you draw or draw and fire when one on one? FloridaState Firearms General Discussion 42 09-08-2010 05:36 PM
Draw weight LeftHanded04 Primitive Weapons, Bows and Crossbows 15 04-09-2009 11:12 AM
Good Draw Weight? mike97878 Primitive Weapons, Bows and Crossbows 11 10-02-2008 01:11 PM
Old 04-21-2014, 11:10 PM
Arejaye Arejaye is offline
Newbie
Originally Posted by Ian321 View Post
I'm only 16 and just got a 175lb pull strength recurve crossbow and can use it with out any devices I don't lift but I do free run and I'm only 5"7 and weigh 155 lbs so hopefully this can help but I may worn that not many of my friends can use it though
If you're that young and strong, and a runner to boot, you need to join my SHTF group/community!
Old 04-21-2014, 11:15 PM
Newbie
I recently got an old used crossbow with no markings anywhere except for a series of numbers stamped into the left side. I have absolutely no idea what the draw weight is. Does anybody know a fairly easy way to tell? Yeah, you can tell I'm a newbie lol
Old 04-22-2014, 02:36 AM
Brew's Avatar
Brew Brew is offline
25 Or 6 to 4
I have a rope roller cocker but I have never used it. Mine is a 175. most of the other guys have to use rope and roller cockers for 150 and 175 bows. I notice sore fingers after about 12-15 shots. I guess I could wear gloves but I want to keep it simple. If you dont use a cocking device make sure to add flourescent string to the bowstring on each side of the bow so you get a straight pull and even alignment with a visual each time.
Old 04-22-2014, 08:41 AM
Highlander20068 Highlander20068 is offline
I love this forum
I would use it, i have tried with mine with just my hands and i notice the inaccuracy because of torquing the string a bit, i always use a rope cocker on mine and i get really good groups because of it
Old 04-22-2014, 09:11 AM
GBG GBG is offline
Debt Is Money
Get two 100# luggage scales (~$10 each). Hold one in each hand and place the hooks where you would grip the string. Draw and cock the bow, but don't pull any harder after you hear the string latch engage.
The scales have two hands on the dial. My old scales have a black one which reads instantaneous load and the red non-returning hand which records peak load, but colors may vary. Add the two red hand (peak) readings together to find the approximate draw weight. On a compound bow the peak draw weight will probably be some distance from the string anchor point, however there are a few "Zero Let-Off" bows where the peak weight is at full draw, just like a recurve.
Some modern recurve crossbows have draw weights above 200#. In this case a pair of heavier fish or meat scales might be used. Also, many newer crossbows have automatic safeties and some are equipped with anti-dry fire mechanism that require the string to be overdraw by an inch or so. If your bow has these, then let a friend read the scales as you pause for a moment after the string latch engages, but before pulling the string back further to engage these safety mechanisms. This will give you the approximate working draw weight of the bow, but of course the max readings obtained when all safeties are engaged is what you really pull when fully cocking the bow. Be careful and have fun.
Old 04-23-2014, 09:33 AM
Kingfish's Avatar
Kingfish Kingfish is offline
My Wicked ridge Invader came with the rope cocker built in to the stock. It has spring loaded recoils on the ropes. Very nice.
http://www.wickedridgecrossbows.com/...cat=Invader+HP
Old 01-17-2019, 02:42 PM
g00gp99 g00gp99 is offline
Newbie
i have a walmart 190 lb bow, and it is a bitch to try cocking, with or without a pull cord, how do i adjust the tension down to about 150 pounds, or less. it is a single blade bow and it fires 16-20 inc bolts. and where would i find the adjust at.
Old 01-17-2019, 07:23 PM
Goblin X's Avatar
Goblin X Goblin X is offline
Third World'er Lunatic
Ive got a old 220 magnum prod Barnett Commando self cocker. makes it easy. but those without, by a goatsfoot lever and install the pins. leverage is your friend. walmart sells hand crank style CCD's for [email protected] for barnett.
my lil crossbow, a barnett trident has the 125 LB prod, and the foot lever for cocking as well....
ID:	282376   Click image for larger version
The Following User Says Thank You to Goblin X For This Useful Post:
Old 01-17-2019, 09:15 PM
Goblin X's Avatar
www.crossbows.net for a more traditional crossbow.........
Old 01-20-2019, 06:36 AM
Aerindel's Avatar
Aerindel Aerindel is offline
Abnormality biased.
120lbs is about the limit of what is fun for me to cock by hand.
I most powerful I ever made was 350 and that was goats foot only territory for me.
These where all medieval styles mind you with linen strings, the one for the 350 was over half an inch in diameter. Its probably different if you use dacron.
The Following User Says Thank You to Aerindel For This Useful Post:
